1)Examine, the board or Running deck, if the holes where the screwdriver are Looses, TIGHT very well, and see if there are doing correct .
Normally this happen when the person training is Jumping, Is NOT normally doing this. Since this machine ARE not Heavy duty like as the machine GYM.
Repair or Replace.
2) As a TIP LUBe the bearing Rollers front and back with WD-40
Blessing.
[email protected]
cell+whatsAPP:+50588611441
SOURCE: Proform Crosswalk Dual Motion Cross Trainer
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
SOURCE: The belt is slipping and making a squealing sound
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
SOURCE: my treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
