What code is showing? and what model are we talking about?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Error Message C3451
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
SOURCE: Error C3451 ! Anyone? Pretty Please.
This is an indication of a reoccurring error or faulty part. You MUST place a service call.
SOURCE: Error message C4551 anyone? pretty please.
This indicates you have a reoccuring error or faulty part. You MUST place a service call for this.
SOURCE: bizhub 250 c1183 fault code
I
had a similiar problem with a Bizhub C-353. I tried opening closing the
front door several time & power cycling galore. Turns out a had a
loose on the saddle tray sensor. I wish the stupid thing would have
just said "Finisher tray full" or something close to it.
efiRules
