Canon Speedlite 430EX TTL Flash Logo
Posted on Jan 04, 2011
After a time, it changes to being extremely bright no matter where I set it
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
67
Points
Had the same problem and after taking apart the base i realized there was a black (maybe optical) wire that was unplugged. Once I clipped it back it worked fine. check the thread here http://photography-on-the.net/forum/showthread.php?t=992635 last post
How to turn off backlight on iphone 4
There is no separate "back light" setting like there used to be on some earlier phones.
In the Settings app of your iPhone, there is a section called "Display & Brightness". You can use that to make your phone's display brighter or dimmer, but as you have probably discovered, it dims or brightens both the foreground and the background elements together as one.
You can turn it all the way down, which is very dim and hard to see in normal indoor light conditions, but may be preferable in extreme low light conditions like in a nightclub setting, or in complete darkness.
Why isn't there a separate back light setting?
To fully answer this, I would probably have get into more than you ever wanted to know about displays.
First, there is really no background or foreground on today's smart phone displays. The foreground elements and background elements we see on the iPhone are really a graphic illusion created by lighting individual pixels with different colors. All of these pixels are on the same plane, so nothing is really behind or in front of anything else. It's just artistically drawn to look that way.
Brightness is simply an "intensity" setting applied uniformly across all of the underlying individual pixels within the display matrix, and has no relationship to color. For clarity, let's look at the difference between lightness in colors, versus display brightness:
COLOR LIGHTNESS is a matter of how much WHITE (all the RGB colors summed, for example) is present in a given color. This has nothing to do with display brightness.
DISPLAY BRIGHTNESS is a matter of how much LIGHT INTENSITY is applied uniformly across all pixels in the display matrix.
At zero display brightness, you would not see white any better than black, blue, green, red or any other color. You wouldn't see anything.
Why did you expect to be able to control the back light?
Prior to the smartphone era, the displays on early cell phones and pagers (and lots of other devices that had displays) had a lighted background that contrasted with dark foreground elements.
The background intensity was a separate setting on those devices, but that's because the background was the only thing that had intensity. The foreground elements were solid black LCD (liquid crystal display) segments that were used to form characters and very simple graphics and lines.
Everything we see on today's smartphone displays is dynamically drawn by lighting different pixels with different colors at different times. Individual pixels on a Retina display are nearly microscopic in size--they cannot be separately discerned by the eye.
Imagine a matrix of microscopic light bulbs, each of which can separately change to any of millions of colors and levels of brightness at any time, on command. Just imagine the sheer number and complexity of possible commands to control a Retina display!
Even if Apple wanted to provide a new feature that enabled us to separately control the perceived "back light", it would only be an illusion as well.
Such a feature would require some sort of complex algorithm to determine which pixels are involved in what you perceive as the "foreground" elements at any given time, so it could add intensity only to those pixels considered to be "background" at any given time.
Since "foreground" and "background" elements drastically change shape (and location) at any time, such a feature would be pretty daunting to implement.
You might be better off using a pure black graphic as your background image if your goal is to have more contrast to make the app icons stand out.
Cheers,
-=Cameron
2answers
Faint picture screen
Press the reset switch to reset the garmin, is the backlight turned off in the settings or is it possibly faulty?
SAMSUNG LCD TV very bright screen
hi Elle924.
this is all i could find out.
What kind of panel do you have - a LED or CCFL one? If it's CCFL then check the inverter board. The main board might be fine (changing the brightness settings changes the signal to the inverter board) but if the inverter board is faulty somewhere then the problem you described may be caused by it
or try this forum.
Why is my tv extremely bright Solved Other Consumer Electronics
or this one might help you.
White too bright in picture on Samsung LCD TV Forums
or even this link.
SAMSUNG LCD TV very bright screen Google Search
2helpful
I would like to reduce brightness on my ASUS VH242H
Actually, the problem isn't with the drivers. Right click on the battery icon in your system tray. Select "Power Options" (NOT Power4Gear eXtreme). On the right panel, select "Adjust the display brightness." Then, select "Change advanced power settings." Scroll down and open up the "Display" box. The options that are affecting your screen brightness on battery are "Allow SmartDimmer to reduce my brightness after," "Have SmartDimmer reduce my brightness by," and "SmartDimmer full-screen video mode." Playing with the percentages in these boxes will affect how your screen brightness adjusts itself. To get my screen to stop re-brightening itself, I changed "Allow SmartDimmer to reduce my brightness after/ On Battery:" to 100%. I then changed "Have SmartDimmer reduce my brightness by/ On battery:" to 0%. Finally, I set "SmartDimmer full-screen video mode/ On battery:" to Maximum Power Saving. This should solve your screen-rebrightening problems even with the 163.44 drivers (I use those too). Please Rate.
Thanks, Anand Fixya
5helpful
2answers
I purchased American Conquest, Amean Conquest: Fight Back, and American Conquest: Divided Nation. They all act a bit strange but the first two work. No matter what I change my graphics card to out of the...
Above solution is a catch-all that does not address the issue. Windows 7 Aero apparently interferes with the graphics of the game. Download the fix which has been made by the fine people at http://cossacksworld.ucoz.co.uk/.
http://www.megaupload.com/?d=Q2WT4L09
Unrar using winrar and follow the text file for help.
Backlighting issues on tv set (I think). Screen goes extremely dark after about 30 min. of viewing. Does not return to orginial brightness unless unit is left off for a long period of time
Lcd tv sets are lit by small glass florescent tubes called cold cathodes and, are powered by: ballasts called inverters... these go out just like your office florescent lighting the parts can be purchased online from electronic parts houses and, are easily replaced
Digital clock display read out is EXTREMELY dim even after adjusting brightness and contrast controls
Hello Jinx55,
the problem is the display unit itself or the cable that goes from the display to the electronic (Most likely the dispaly itself).
The display will need to be replaced. You can contact Miele directly at
(800) 843-7231
1helpful
The screen won't light up and when the screen slided up the screen display becomes too bright (white) that nothing can be read off it
My MDA loses its settings frequently as well. Go to Start, Settings, System, Backlight, and see what it looks like. Maybe the settings have changed.
Screen is Extremely Dark!
Good Day, Cary;
PICTURE IS DARK WHEN OSD CONTRAST MENU ADJUST LEVEL CHANGES.
Cause: SHORTED ZD-309.
Also, increase Screen controls at front of TV and see what pix brightness does . Hopefully you did check brighteness & contast levels. When adjusting Sreen controls set contrast control at about 90% and brightness at about 50%.
Good Luck, big IRISH.
Screen problems
Your internal LCD screen is damaged and you will need to replace it.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
