Doubtful it's a wire. If you have taken it apart by now, (and don't attempt it with out the service manual. see http://servicerepairmanuals.net/hifi/korg-sp-200-service-manual).
Use extreme caution and delicate care when unplugging the ribbon cables.
The jacks for the damper, headphnes and L & R outputs are of a cheap plastic housing that cracks and breaks apart. also there is no mounting nut on the jack for stability; not tht it matters since Korg dsigned the board so that the threads don't extend out from the housing. a very serious "FAIL" on the part of Korg engineers.
the easiest fix? get a new board. but, they will just break again.
the best fix? replace those plastic jacks with a Quality circuit board mount type; see Mouser electronics, or Allied electronics.
I'm having to replace 3 broken jacks. if you are able I'd recommend replacing all 4 jacks.
Take it apart and see if there are any loose wires. If not, try to find screws that will replace the lost ones.
