Vehicle Parts & Accessories Logo
Posted on Jan 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I've just changed the battery today, then the radio doesn't work. I don't know the radio code as well. what should I do?
Dan Doherty
Level 3:
Genius:
  • Master 1,099 Answers
  • Posted on Jan 04, 2011
Dan Doherty
Master
Level 3:
Genius:
Answers
1099
Questions
Helped
386683
Points
3389
Hi
a dealer should be able to give you the code if you get the serial number from the radio, also are you sure the code is not in with your car books, service manuals and book packs, often it is in there o a small credit sized card. alternatively some radio decoders will come to you at home, they charge about £25 in the UK to recode the radio.
Hope this helps
Regards
Dan
I have a 1991 celica and for some reason the front signals does not work at all. When I turn on the blinkers it blink really fast on both sides but hazard light works fine it blinks normal but it...
check the main earth wire near the battery. and one near the rear of the lights. unbolt them and clean the connectors up put some grease on them after. then check again. remember that when the earth wires come off the radio code will be needed to reset the the radio. be safe and take the battery off.
Why wont radio work after replacing battery?
by replacing the battery the anti-theft code requirement has been activated
check the radio forums and comments on this site as there are ways to recover the code
I don't know how to change the minutes on my clock. It's a jeep wrangler. I've tried holding in the time button and turning tune knob, doesn't work. Thanks!
is there a h/ m with two little holes any where on the radio? usually on the right or left of the clock. if so stick a paper clip into the hole and set. if not i would try the FF and the RW buttons
My acer tablet a110 wont charge over 50 percent
The battery pack is exhausted replace it.
Apr 05, 2017 • Cell Phones
Chrysler 2005 radio not working
i am not positive but if he disconnected the battery to perform his task then it may be that you need the code to reset the radio.
1helpful
2answers
I have a 2000 chevy silverado 1500. 3 nights ago, my truck started up just fine with no problems and has never had a problem starting up. The next morning, I tried to start it and the dash lights and radio...
do you have remote start on that truck? if you do, it has a hood safety switch that will keep it from starting if hood is open. That hood switch is quite easily identifyable. Look for it on the drivers side, either close to the firewall or right at the front of the fuse box.itsa worth taking a look
Anyone have the code to reset this radio. battery went dead now the radio will not come on ?
Try checking your fuses. If the radio doesn't come on a code is not going to do any good. As far as I know these radios don't require codes anyway.
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
