Hello sir,
there must be software problem or else there will be some hardware problem i you mobile.you should contact the company dealer of your mobile.because the will find the exact fault in your mobile and try to fix this problem.they will check your mobile completely and fix this problem.just go on with your company.don't go on with local service center.have a great time.
thank you
SOURCE: phone start-up failed.contact the retailer. Is
turn of the phone. press 3 greenbutton and star key all at thesame time then turn youre phine on whiolw holding all three keys at thesame time. it should format it n restore to factory default
SOURCE: 3230 start up failed
u need to format it manually by pressing power on, call options, 3 & * simultainously tested and proven!
SOURCE: 7610 Gsm start up failed,contact retailer.
System might be damanged,
You can hard reset the phone (Factory Settings)
This will reinstall the operating system inside the phone back to how it first was.
(internal memory gets formatted then the rom reloads the os back)
(Solves all kinds of problems.)
Switch the phone "OFF"
Hold "3" (button) + "Green Call" (button) + "*" (star button)
Switch the phone "ON" while holding the above three buttons.
Continue holding for about 20 seconds then let go.
Please note this will format all the saved information stored in phone memory. including phonebook numbers (if not stored on SIM card).
Try to make backups first.
You have been "Warned".
Best of Luck.
SOURCE: nokia 5530 xpress music phone start up failed
There can be a short circuit or any criticle problem therefore protective circuit in ur phone are activated & they stops phone to ON for avoiding the harm to u & ur mobile. It is appropriate to contact ur retailer or service center
