Question about Sony KV-35S42 35" TV
I have sony triniton tv when i was turn on there is horizontal line on the center of screen this problem was never happen before
  • Sony Master
  • 6,694 Answers
HI,
ur tv has problem with its vertical scanning side. vertical scanning output ic (integrated circuit ) may have some problem ( faulty or dry soldering in its leads). u can easily find out the vertical ic on ur tv. there will be four wire coming from the coil which is fitted on the picture tube neck, of which 2 will goto horizontal scanning section and the remaining two will go to vertical scanning section. just follow the two thin wire (normally in color green and yellow ). it will goto a socket on the main board. follow the track on the board. it will lead u to vertical scanning section. check for any dry soldering, if not , replace the ic.
ok
Posted on Jan 04, 2011
SOURCE:
My Sony Bravia 46" has a 1" thick black line horizontally thru the middle of the screen. It separates the top and bottom. Has anyone seen this happen before?
It sounds lcd screen problem and lcd panel (screen) will be replaced. Please check with local tv repair shop or nearest Sony service center for lcd screen replacement.
Jun 17, 2010 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Three coloured lines appered on the screen - no picture
If there is no picture and 3 vertical lines in the center of the screen, stop. Turn off TV. You have no horizontal deflection happening. Lines will burn into crts and be permanently visible after repair.
No horizontal deflection is caused by Horizontal sweep circuit failure, maybe flyback transformer and associated components. More than a simple do-it-yourself repair.
easyab
Apr 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
We have a Sony Triniton 32 inch TV we bought approximately in 2000. For a couple of weeks we had horizontal lines across the screen, then it just went black, no audio, nothing. Just comes on and off....
It is probably you horizontal output or horizontal output drivers. The newer TVs derive all there power from the horizontal circuit. This can only be fixed by an experienced technician as that area produces in excess of 20,000 volts to light the screen. Don't try to fix it your self as you could cause more damage or be electrocuted.
Oct 07, 2009 | Televison & Video
A horizontal through the screen,from left to right,TRINITON TV
This is a Vertical circuit failure. A number of parts can cause this. Vertical Output IC and or any of the peripheral components that work with it. Sorry, that is all I have for this.
Hope this helps,
Skyassoc
Jun 22, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Green horizontal line in center of screen.
Bad vertical output ic. Also, check resistors and diodes around vertical output ic.
Mar 23, 2009 | Sony KP-46V35 TV
I have a KV27FS210 sony wega trinitron tv. It turns on and has a single horizontal line across the center of the screen then buzzes shows a continuous zigzag line from the top to bottom of the screen with...
The single horizontal line is a problem with the vertical circuit. Look for a small flat id attached to a heatsink that should be marked LA7837 or something similar. Try resoldering the pins of this IC first. If that does not resolve it, replace the IC.
Keep us posted.
Dan
Feb 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Triniton worked fine, turned it off and now it won't come back on.
The power supply, and or one of the scan amplifiers has a problem.
I have serviced these for defective horizontal output transitors, and the flyback failing. When this happens, most of the time the power supply had to also be serviced. There are number of support components that can cause the failure in the first place.
The set will have to be serviced by an experienced service tech.
Jerry G.
Apr 17, 2008 | Televison & Video
Green screen with almost horizontal zigzag lines
Is good that you hit it and it reacts,very likely you have loose conections in different places but for the distorted picture you need to check the horizontal driver transformer and flyback after that is corrected you need to check the complete chassis for loose conections.Take your time.Good luck.
Sep 07, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-35S42 35" TV Logo
143 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
