Also follow the generic troubleshooting steps mentioned in the link to connect a wireless keyboard and mouse to a computer. http://support.microsoft.com/kb/838398
Note: The steps provided in the link mainly works for Microsoft hardware but the steps can be applied to any wireless keyboard and mouse. Do not install any software given in the link as it will not help you if you do not have a Microsoft Hardware.
It would be helpful if you could provide us the exact computer model number and also the make and model number of the keyboard and mouse.
1. Pointers to see if you can use the existing driver, it maybe disabled there, or the settings need to be changed.
2. If it is disabled or unusable in pointers go to device manager and check if there is a yellow balloon next to the mouse, if so you have to replace the corrupt mouse driver software. global download gateway com
See if the mouse pad has been accidentally turned off. This can be done
via the "Function" button on your Gateway laptop. To enable your mouse
clicker again on your Gateway, head on over to the "Control Menu" in
Windows and double-click on the "Control Panel" icon.
Click on the "Mouse" option under the "Printers and Other Hardware"
tab. In the next menu that pops up, click on the tab listed as "Device
Settings." From this menu, you should be able to locate a listing for
the mouse pad on your Gateway laptop. Click on this listing. From here,
you should be able to enable the mouse again. Click "OK."
Head over to the official Gateway site online (see
Resources). The above enabling of the mouse device under "Device
Settings" may not have worked. Make your way to the "Software and
Drivers" area of the site.
Check over your Gateway manual and find your specific serial
number for your machine. Enter the number into the Gateway site when
prompted and check to see if any driver updates exist for your mouse on
your machine. If so, click to download the update, and then double-click
the file on your computer to install it. Restart your Gateway laptop to have the changes take place. Your mouse should now work.
Scroll on mouse pad may not be a "default" factory setting. Go to Control Panel and access Mouse Settings and look for this feature and activate it.
If this does not work then go to Gateway Website and look for SOFTWARE AND DRIVER DOWNLOADS ., Select your model and Operating System and look for MOUSE. Select Moust Driver Download and RUN and reinstall driver.
If both do not work than your mouse pad has to be replaced due to physical issue
have you tried connecting the mouse to another computer? usually this will require a restart but if it did not work that way, please have the mouse tried on another computer
