I have a Ricoh CL 3000 and have begun to notice some vertical "streaking" in printed images about 1 1/2 to 22 inches from the left side of the paper. There are no error codes or consumable replacement codes, but this issue appears on both B&W and Color prints, but is most prevellent with color printout. Trying to ascertain which consumable may be causing this, PCU's, transfer belt, fusing unit etc. The printre has run flawlessly and only has a total page count of just under 6000. Any help, most appreciated....
The following is taken from the service manual I hope it helps thanks J
4.3.1 BLANK PRINT
Symptom Possible cause Necessary actions
Defective laser scanning unit Replace the laser scanning
unit.
Defective PCU Replace the PCU.
Defective transfer belt unit Replace the transfer belt
unit.
tension unit
tension unit.
Defective toner cartridge
drive unit
Replace the toner cartridge
drive unit.
agitator
Replace the toner cartridge.
Incorrect action of transfer
roller
Check the guide and the
transfer roller.
Defective high voltage
supply board
Replace the high voltage
supply board.
No image is printed.
Defective engine control
board
Replace the engine control
board
4.3.7 WHITE HORIZONTAL LINES OR BANDS
unit.
White lines or bands appear
in images of all toner colors.
They are vertical to the
paper feed direction. Defective transfer roller Replace the transfer roller.
4.3.8 MISSING PARTS OF IMAGES
unit.
Some parts of images are
missing.
Defective fusing unit Replace the fusing unit.
4.3.11 DARK IRREGULAR STREAKS ON PRINTS
Unexpected streaks appear
at irregular intervals.
Defective transfer belt Replace the transfer belt
unit.
4.3.17 NO PRINTING ON PAPER EDGE
Defective toner cartridge Replace the toner cartridge.
unit.
images are not printed in the
areas around the paper
edges.
Transfer belt not contacting
PCU
Check the belt tension unit.
Try these hope I could help Thanks J
Sometimes the PCUs can be covered under warranty. At that count it was probably defective. For it to happen on black and white as well could be a transfer belt. Fusers don't cause lines because the toner is already applied to the copy before it gets there from the drum and the transfer belt.
please try to examine the transfer belt. if this not resolved its recommended to bring the unit to the nearest registered repairman in your area.
melnavz
Greetings,
Check the Photoconductor unit if scratches are present.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
The first thing I would do would be to put the old toner cartridge in if you still have it, if not try a new one. If that doesn't solve the problem you may need either a new fuser or transfer roller.
Well in most laser printers the cause of the lines could be a scratch on the actual toner, dirty toner cartridge, or even the fuser. when these are the cause, you wont be able to see any consumables error message. you may try cleaning it out first before doing any replacement, it is worth a try.
to check the anatomy of your printer:
http://www.retrevo.com/support/Ricoh-CL3000-Printers-manual/id/261ci371/t/2/
cleaning:
http://www.ehow.com/how_3675_clean-laser-printer.html
In my experience, the fuser has always been the cause of the lines.
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Thanks for the info...Ispoke to a technician at Ricoh and they are leaning towardsthe problem being related to an "almost expended" Color Photoconductor Unit....so, I still have the dilemma.....
Comment by mburney, posted on Jul 09, 2008
No obvious scratches or damage to the PCU....
Yes, I understand that I need to replace "a" part, but I am trying to get a consensus as to which part to replace.
I have examined he transfer belt and there does not appear to be any problem. No scratches, dents, dings or imperfection.
Im going to oder a color PCU and see if that does the trick, if not, I guess the transfer belt unit will be next....
