Sirius Starmate ST2 Satellite Radio Receiver Logo
Posted on Jan 03, 2011
My sirius starmate says "antenna not detected".
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Apr 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
9801
Points
20
The antenna that needs to be replace!
http://satelliteradiofix.com
Which plug(connection) on bottom of ST5 sirius radio is the antenna plug?? keeps losing the antenna, i have replaced the base with the same error ocuring
The small, gold, circular connector on the bottom of the unit. You can purchase a repair on eBay if the antenna connection has loosened itself from the board.
Radio shows antenna not deteted or acquiring signal but does not work . antenna and all connections are good, ??
The problem is likely the actual connection inside the Starmate. It sounds like you have tried alternate antennas, which can only mean the unit itself has an issue. What has likely happened is the antenna jack inside the radio has come loose and is no longer making a connection, in which case it could be repairable. Otherwise there are plenty of other 12v Sirius receivers compatible with the same connections if you are looking to replace the head unit.
Have a sirius starmate 5.have tried new dock,new home dock,and new antennas."antenna not detected"appears on screen.can get signal if I push reciever down,or move it on dock;but will not maintain...
Remove the back cover on your radio. The antenna connector is located on the right of the dock connector. Carefully resolder the connections. There are 2 pins (they lead to 3 contacts). Very easy repair, all you need it a fine tip soldering iron and some flux. You can get those for around $15 at wally world.
2helpful
2answers
My Starmate 5 constantly has to acquire signal in my car at home it works perfectly.Any suggestions?
Check the antenna's connector for your car based antenna. Sometimes the little finger tabs need to be gently pushed back towards the center to make a better connection. Be careful not to move them more than a precision screwdrive blade's width or you might snap it off.
Receiver not "receiving"
where is the antenna located make sure it is not covered by anything. Also make sure there are no kinks or breaks in the antenna wire
1helpful
Reception
Check your antenna wire to see if it is spliced or cut. If you do not recognize a problem still you can usually get very good help from calling Sirius. They have been good about trouble-shooting and repairs.
3answers
2answers
Starmate 4 acquiring signal
With the antenna plugged in, it may take a minute to aquire the signal. If it takes more than a minute there is a problem with the antenna or the reciever.
3helpful
4answers
Sirius Starmate 4 - locks on the "Sirius: screen
with starmate 3 press at same time menu +memo+band with the radio on (with sirius screen only)
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
