SOURCE: Annoying Songs!!!!
Try the USB connection. Shut down the Yepp, press and hold the "back arrow" button, plug it in the USB (with the arrow button still pressed). After a few secons your system will recognize the Yepp as a USB disk, so you can go to the folders and delete all the junk.
SOURCE: ONLY PLAYS PART OF SONG
enter you menu and turn off review. Review plays 5 or 10 sec of every song on your player if its turned on. Trun it to normal and you should be ok....
Rate this solution if it helps.. Thank You...
SOURCE: MY SANSA WONT PLAY SONGS, IT SHOWS ARTIST BUT STUCK IN PAUSE
Some songs are in the wrong format, or your DB is corrupt. Either way:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
SOURCE: Ipod touch keeps repeating songs on all playlists
when you are playing a track holding the iPod Upright on the Left hand side under the Track Time there is a Symbol with two arrows in a circle. If this is Blue you are on Repeat All, Blue with a 1 is repeat Track. You want it to be White. On the Right is Shuffle. Good Luck!
