Computers & Internet Logo
Posted on Aug 17, 2017
I'm using WebPlus 4; and want to restrict access to a page on my web site. I'm using smart objects, user groups (from Access Control objects) to log into the page. That is working OK but I cannot 'Log Out ' of the page and the page is always accessible! I've tried everything; the only way to get the page back to a 'secure page' is to delete the user group and start again.. many thanks
5 Related Answers
Anonymous
  • 50 Answers
  • Posted on Jan 23, 2008
SOURCE: UNABLE TO OPEN GROUP POLICY EDITOR
I'd suggest downloading and installing the Server 2003 Administration Tools. There were updates to several over the course of the last two service packs and may fix your problem. They are downloadable via http://www.microsoft.com/downloads. Do a search for Administration tools or adminpak.msi
fidoliedo
Gary Luis
  • 162 Answers
  • Posted on Jul 25, 2008
SOURCE: Domain\administrator has no local admin rights
You may need to edit group policy if this was once in a domain. You may want to try rebooting the machine and logging into the 'LOCAL' machine and see if you have rights that way. Each machine by default has one administrator account but if the server was part of a domain, that right may have been removed. You may need to reset OWNER privileges for all files in the machine.
Anonymous
  • 849 Answers
  • Posted on Nov 26, 2008
SOURCE: Windows XP Does Not Allow Inbound/Outbound Connections
re-installing windows will solve all your problems.
Anonymous
  • Posted on Dec 26, 2008
SOURCE: Missing user names and groups from "Security settings" window
You have to backup all SYSTEM files and reinstall the OS. That's the ultimate solution to your problem.
Anonymous
  • 108 Answers
  • Posted on Jan 17, 2009
SOURCE: i can not log in Call 1-8O5-225-669O We are 24 Hour Available Call Now To Customer Service
log on to your router > click on status> in left pane click on logs. Older logs are deleted when memory full.
If running the SYSlog utility you can save to a folder on your computer. You name the folder.
Link to manual:
ftp://ftp.dlink.co.uk/dir_products/dir-635/DIR-635_manual_10.pdf
1helpful
I want to put a password at my lexmark printer could that be done.
The User guide has all the information you need to perform thsi action.
Setting Password Protect for the menus
Apply an administrative password to restrict unauthorized users from making changes to the MFP configuration from either the control panel or the Embedded Web Server (EWS).
1 Touch the Menus button on the home screen.
2 Touch Settings.
3 Touch the down arrow and then touch Security.
4 Touch the down arrow and then touch Create/Change Passwords --> Create/Change Advanced Password.
5 Enter and reenter a password of both alphabetic and non-alphabetic characters. The password must be a minimum of 8 characters.
6 Touch Submit.
7 Touch Settings --> Security --> Password Protect to view what configuration settings are protected by the
Advanced Password.
Note: Settings --> Security --> Password Protect and Settings --> Security --> Create/Change Passwords --> Create Change user Password can be used to restrict access with a different password than the Advanced Password. Use Settings --> Security --> Password Protect to select the menus that are accessible with both an Advanced Password and a User Password.
Note: The Advanced Password and the User Password protect the menus on the touch screen control panel of the MFP and the Configuration section of the EWS pages.
Restricting Function Access
The MFP supports a variety of methods for authenticating users prior to allowing access to functions.
1 Open a Web browser. In the address line, enter the IP address of the MFP being configured using this format:
http://ip_address/.
2 Click Configuration.
3 Under Other Settings, click Security.
d Select an authentication method.
e Click Submit.
4 Click on the setup link for the authentication method previously selected in step d.
a Fill out the appropriate information for the environment.
b Click Submit.
5 Click Function Access.
a Set the function authentication level for each function. Select Off to prevent anyone from using a function.
b Click Submit.
Preventing access to the menus from the control panel
It is possible to prevent access to all the menus using the control panel touch screen. To prevent access:
2 Touch Settings.
3 Touch the down arrow.
4 Touch Security --> Function Access --> Menus --> Disabled.
5 Touch Submit.
I have a business requirenment that when user open the web browser it should get routed to a specific web site and then do a registration and after registrtaion he is free to use the internet and surf net....
If the user is outside your business you don,t need to it.If the user is on your network you can allow or restrict the access to the internet.The option you want to can be made in your web server by the webmaster.I think your bis is an internet cafe.So you need to make a page to do this kind of interface.If you run an internet network for your clients you need to let them to pay for it.
You can use a third party software to restrict user to access internet.
With iNet Protector you can restrict access to the Web and password protect Internet connection. You can restrict internet access at specified times or on demand. You can disable connection completely or limit Internet to work with allowed programs and services only. In order to fully enable Internet access, user defined password must be entered. You can easily schedule Internet availability. Timer allows you to disable Internet connection after specified amount of time. Very useful for parents and business owners.
Key features:
* Restrict Internet access at specified times
* Password protect Internet connection
* Enable and disable Internet on demand
* Allow Internet access for a specified amount of time
* Allow only specified services or programs such as e-mail
* For Parents - Protect your kids from using Internet too much
* For Businesses - Keep employees from online entertainment at work
Internet Access Controller is a leading software tool for controlling, blocking web sites and restricting internet & network access.Internet Access Controller can restrict internet access at specified times or on demand. You can password protect an internet connection. Protect your computer from viruses, trojans, worms that can be contracted from malicious websites or programs. Great for parental control or to prevent employess from inappropriate internet usage. You can block, limit or allow which programs and services have access to the internet. The timer feature allows you to disable the internet connection after a specified amount of time. IAC gives you complete control over your computer's network connection.
Key features and benefits
- Restrict internet and network access automatically at specified times
- Password protect internet and network connection
- Enable and disable internet on demand
- Allow internet access for a specified amount of time
- Allow only specified services or programs such as e-mail
- Allow only specified web sites
- Block specific web sites and allow the rest
- Set daily internet usage limits applied to all users or only specific users
- For Parents - Protect your children from the dangers of the web and limit online usage
- For Businesses - Keep employees from online abuse at work
Parents: Protect your children
- Limit time spent online
- Automatically turn off internet at night or at any other inappropriate time
- Block harmful programs, such as chat and online games
- Protect your computer from malicious websites or programs.
Businesses: Increase employee production at work
- Increase productivity by limiting temptation for inapporpriate web surfing.
- Only allow websites needed for daily tasks.
- Block unwanted websites or games.
- Only allow access to programs such as email, file sharing and business related programs.
If you use NTFS, you can use the file system's built-in permissions to restrict access to the Internet Options or Internet Tools Control Panel applet by performing the following steps:
  1. Start Windows Explorer
  2. Navigate to \%systemroot%\system32 (e.g., c:\windows\system32).
  3. Right-click inetcpl.cpl and select Properties from the context menu.
  4. Select the Security tab.
  5. Adjust the user and group permissions as appropriate, and ensure that the SYSTEM group has Full Control.
Myspace and twitter is being blocked by k9 web protection and i want to get on it but cant.how do i bypass the k9 web protection
Well have you installed K9 or your parents? :D. If they did I m sorry to say that its better for your own good ha ha. If not you can configure it to allow myspace and twitter. But still I will not tell you how to bypass since I don't know whether you are a kid.
If you have not already logged in, enter your administrator password at the prompt and click OK. From the Setup menu, click Web Categories to Block. By unticking the tick for social networking (if it is ticked) you will be allowed to access any social network. Save the configurations.
Click URL key words Check whether those URLs have been blocked (full url and / or by words. You can clear the saved settings by allowing them.
There is another way of unblocking the site.
To override a blocked Web site: 1. On the Category Blocked page, choose an option under Allow This Site. The following figure shows an example. 2. From the Allow access to list, click one of the following options: • for 5 minutes to allow temporary access to this site for the next five minutes. • for 15 minutes to allow temporary access to this site for the next 15 minutes. • for 30 minutes to allow temporary access to this site for the next 30 minutes. • for 60 minutes to allow temporary access to this site for the next 60 minutes. • permanently to always allow access to this site. If you choose this option, one of the following happens: • If the Web site was blocked because of its category, the Web site is placed in the always allow list • If the Web site was blocked because it was in the always block list, the Web site is removed from the always block list. 3. Click Allow This Site. 4. You are required to enter your K9 Web Protection administrator password to confirm the action. This is how the "Block access by time of the day" works.
K9 Web Protection enables you to restrict the time of day users can access Web sites. If there are specific times when you do or do not want your family accessing the Web, this feature assists you in enforcing that policy. To restrict Web browsing access times: 1. Start K9 Web Protection 2. From the top menu bar, click Setup. 3. If you have not already logged in, enter your administrator password at the prompt and click OK. 4. From the Setup menu, click Time Restrictions. You have the following options: Unrestricted NightGuard Custom.
Just select the Unrestricted or modify Custom to re adjust the settings.
Adding a web site exception (Advanced). This is how its done.
You can create exceptions for any of the following reasons: ? Web sites that do not belong to any category ? Web sites you know your children access frequently, so you can make sure you enforce the appropriate action (allow or block) ? To allow access to specific Web sites that belong to a category that you otherwise want to block To set up Web site exceptions: 1. Start K9 Web Protection 2. From the top menu bar, click Setup. 3. If you have not already logged in, enter your administrator password at the prompt and click OK. 4. From the Setup menu, click Web Site Exceptions. Then exceptions can be added.
To remove the exception just remove the setting or add it to Always Allow.
To override a block and access blocked Web pages, you must enter the administrator password you configured when you installed K9 Web Protection.
Special cases.
If a Web page was blocked because it was on the always block list or because it is classified in a category you chose to block, you can ask Blue Coat to review the Web site’s rating as follows: ? You can request Blue Coat associate the Web site with more categories ? You can request Blue Coat reclassify the Web site, if you believe the categorization is incorrect.
Enjoy!
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem... Thanks for contacting Fixya
Passworded user from old pc to new pc
How to take ownership of a file loadTOCNode(3, 'moreinformation'); You must have ownership of a protected file in order to access it. If another user has restricted access and you are the computer administrator, you can access the file by taking ownership.
To take ownership of a file, follow these steps:
  1. Right-click the file that you want to take ownership of, and then click Properties.
  2. Click the Security tab, and then click OK on the Security message (if one appears).
  3. Click Advanced, and then click the Owner tab.
  4. In the Name list, click Administrator, or click the Administrators group, and then click OK.
    The administrator or the administrators group now owns the file.
To change the permissions on the file that you now own, follow these steps:
  1. Click Add.
  2. In the Enter the object names to select (examples) list, type the user or group account that you want to have access to the file. For example, type Administrator.
  3. Click OK.
  4. In the Group or user names list, click the account that you want, and then select the check boxes of the permissions that you want to assign that user.
  5. When you are finished assigning permissions, click OK.
  6. You can now access the file.
How to take ownership of a folder loadTOCNode(3, 'moreinformation'); You must have ownership of a protected folder in order to access it. If another user has restricted access and you are the computer administrator, you can access the folder by taking ownership.
To take ownership of a folder, follow these steps:
  1. Right-click the folder that you want to take ownership of, and then click Properties.
  4. In the Name list, click your user name, or click Administrator if you are logged in as Administrator, or click the Administrators group. If you want to take ownership of the contents of the folder, select the Replace owner on subcontainers and objects check box.
  5. Click OK, and then click Yes when you receive the following message: You do not have permission to read the contents of directory folder name. Do you want to replace the directory permissions with permissions granting you Full Control?All permissions will be replaced if you click Yes.
    Note folder name is the name of the folder that you want to take ownership of.
  6. Click OK, and then reapply the permissions and security settings that you want for the folder and its contents.
Source: Microsoft
Hi..I've got the evaluation taster set up on my 10.4 Mac. However it won't let me even get onto hotmail. What have I done wrong please?!
Go to this link below to download a manual for your software:
http://www.intego.com/pub/Manual_CBX4_en.pdf
From page 63 in your manual:
Using Web site Exceptions
In addition to using ContentBarrier X4’s built-in filtering categories, as described above, you can also restrict user access to certain web sites. You can add specific sites that are always allowed, and others that are always blocked. (You also have the option to only allow web access to certain sites; see Restricting Web site Access below for more on this
option.)
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
2answers
How can i block certain website (mostely the torrent site)parentally. And prevent from downloading the torrent PERMANENTLY.
I use TrendMicro (about $40/year for three machines). You have decent parental control with it. You may also use "Resticted Sites" settings in Internet Explorer but it may not be as secure for you. The TrendMicro software requires a password to allow settings to be changed...not sure about IE.
I want to make a system for viewing exam schedule but i don't know how. please help
Are you trying to set up a web page that is accessible to a certain group. This can readily be done be establishing a free account at www.windows.live.com
Then use the skydrive feature to upload files to your webspace, create a group you want to make it accessible to, and set your preferences and profile characteristics to limit who can access those pages, and how they must access them. Then you simply add the list of people to your group, and direct them to the site.
There's a bit of a learning curve involved, but worst case scenario is the schedule is open to public view. Just make sure you restrict group member's access to the core files, or someone may hack your schedule.
Consult this link for an overview: http://help.live.com/help.aspx?project=live_folders&market=en-US&querytype=keyword&query=qaf&tmt=&domain=cid-f8eea3ee83bd9d35.skydrive.live.com&format=b1
And use the help area inside windows live to learn your way around.
If this actually solves your problem, please take a moment to rate this post. Thanks!
2answers
TERMINAL USER SECURITY IN WINDOWS 2003
please define users & give him restrictions as well as rights,
make them as an standard user (dont define them as an administrators) if u have some applications which have to be use by terminal users then give them only that much of applications..
dont allow them to use anyother applications..
Asp
Hi, Have you checked your security permissions on the 2003 IIS ?
Are the users using it as Intranet or Internet?
Is the site internal/external or possibly firewalled with rules restricting correct port operation and access permissions?
x-b-m
Top Serif Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Serif Computer and Internet Expert? Answer questions, earn points and help others
