NorStar Meridian M2616 Phone Logo
Posted on Jan 03, 2011
I pressed something on my M216 when checking my voice mail and now my phone message and all prompts are in spanish. I need to know which commands to press to change them back to english
Anonymous
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Feb 15, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
4986
Points
38
Look through your instruction book, then do a internet search. And, if all else fails, start learning Spanish.
2answers
How to change voicemail on a galaxy 5
  • From the Home screen, tap , then tap Call icon.
  • Follow the tutorial to create a password, record a greeting, and record your name.
Note: These steps may be different depending on your network.
Accessing Your Voice Mail
  • From the Home screen, tap Call icon, then tap Voice Mail icon. You may be prompted to enter a password.
  • When connected, follow the voice prompts from the voice mail center.
Accessing Your Voice Mail From Another Phone
  • Dial your wireless phone number.
  • When you hear your voicemail greeting, press the asterisk key on the phone you are using.
  • Enter your password and you are connected to your Voice Mail.
Turn off voice command
Press the Voice Command key, and when prompted, say turn prompts off. To turn Voice Command on, press the Voice Command key and say turn prompts on.
I hope that you have found this information useful, and if I can be of further assistance, please let me know. Thank you for using fixya!
How to set up voice mail
Verizon's voice mail service accepts messages for you when you are busy, or just don't want to answer the phone. The basic service will record up to 20 messages, with a three-minute maximum per message. The messages are held for 21 days, after which they are deleted automatically. Voice mail is usually included when you first activate your service, and you can check to see that you have voice mail from the "My Verizon" account area on the Verizon website. Once you have established you have voice mail on your account, you can set it up by programming it.
Sponsored LinkGet 30 days of 3G @ Rs 99ideacellular.com/DataplanGet 300 MB @ Rs. 99 Only. Now Upto 70% Discount on Idea 3G Plans! Step 1Press "*86" and then "Send" from your phone on Verizon's network. "86" are the characters "VM" using the alpha-keys. Then enter your wireless phone number. Press "#" when you hear the greeting. Follow the prompts to set up your password, greeting and mailbox options and then end the call when you're done.
Step 2Press "*86" and then "Send" from your phone. If you're not on the Verizon network, enter your wireless phone number. Press "#" when you hear the greeting. Then enter the password, followed by "#." Listen to the messages and then press "7" to delete and "9" to save.
Step 3Rerecord your greeting by choosing "Personal Options," which is the number "4" key. Options include notification options and other greetings like "Extended Absence." Follow the voice prompts to navigate through the tiered system.
Step 4Verify your voice-mail indicator is working by accessing your voice mail and pressing the number "4" key. Press "1" to toggle the message-waiting indicator on or off. Listen to the announcement that tells you how it's set.
I don't know how to set up voice message
If you mean setting up voice mail out-going message, then see below (for AT&T cell service). The phone will dial the voice mail center for you after you set it. Then it will check the number of messages on the system. Press Menu > Messaging > Settings. Then select Voice Mail and enter the phone number for the call center. Then press the AT&T button to exit.
To listen to the messages, press and hold 1 or press Menu > Messaging > Voice Mail. Then the number set above will be dialed.
To set up the voice mail box, start as you would for listening to the messages above. Note: you must use your wireless phone and be inside the AT&T coverage area.
To set up your voicemail box:
1. Follow the prompts to create and enter a 4- to 15-digit voicemail password.
2. Record your name and personal greeting, then press the # key
3. After completing the setup process, press * to return to the Main menu.
See http://www.wireless.att.com/answer-center/main.jsp?t=solutionTab&ft=browseTab&ps=solutionPanels&locale=en_US&_dyncharset=UTF-8&solutionId=52653&isSrch=Yes for more information.
For another provider, see their documentation.
To create a memo for yourself, press Menu > Tools > Voice Memo (or if using the advanced menu, Menu > My Stuff > Tools > Voice Memo). Then press Options > New (or Create New, if you have created one before). Press Re-rec to record and pause to momentarily stop recording. Press the AT&T button to stop recording. Press Play to play back a memo and the AT&T button to stop play-back.
I hope this helps.
I need instructions on how to set up voice mail , and how to retrive missed calls
Voice mail: press [Messages] button, enter code when prompted, follow voice prompts
Missed calls: press [Directories] button, press [Missed Calls] softkey, scroll through numbers
How do I set up voicemail? New phone, mailbox says it is full, how do I delete messages?
  • Access the main menu of your Samsung Go Phone. Hold the #1 key down until you are connected to the voice mail system. If for some reason pressing the #1 key doesn't connect you to voice mail then call customer service at 1-800-331-0500. You will be connected with an operator who can help you troubleshoot the voice mail problems on your Go Phone.
  • 2 Follow the voice prompts and select "Listen to Messages" from the list of options. Bear in mind that checking voice mail on a Samsung Go Phone will count against your prepaid minutes.
  • 3 Once you have finished you can select the "Delete Message" option from the voice prompt if you wish to clear your voice mail messages. If not, you can simply press "clear" or hang up the phone to leave the voice mail system.
  • 1helpful
    Setting up voicemail on sch-u340 phone..cannot read buttons on manual to set up..
    Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
    http://www.samsung.com/us/consumer/mobile/mobile-phones/more-carriers/SCH-U340ZBAUSC/index.idx?pagetype=prd_detail&tab=support
    Setting Up Your Voice Mail from page 10 in your manual:
    Voice mail allows callers to leave voice messages, which can be retrieved any time.
    Note: Once your voice mail account has been set up, you can use the Voice Mail folder (under the Message menu) to view details of voice messages in your voice mail box.
    1. In idle mode, press and hold the key or dial your own mobile number
    to dial voice mail.
    2. Follow the prompts in the new user tutorial to setup your mail box.
    Listen to voice mail
    to dial voice mail. After connecting, you will hear your voice greeting.
    2. Interrupt your greeting by pressing .
    3. You are then prompted to enter your password.
    Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
    JimmyC
    Set password for voicemail
    1.Turn your phone on and press and hold the "1" button on your keypad in normal standby mode.
    2.Enter your four digit passcode with your keypad and press *. If you do not yet have a passcode, you will be prompted to create one.
    3.Press "1" to listen to the options in English, or "2" to listen to them in Spanish.
    4.Press "1" to record your own voicemail greeting. Wait for the beep and speak your greeting into your phone. Press "1" again to confirm your greeting.
    5.Press the red "End" button on your keypad and your voice mail will be set up. Press "1" again or at any time to listen to your voicemail by entering in your passcode and following the prompts to navigate your different messages.
    Let us know if this helps ...
    Thanks
    Shiv.
    I have a panasonic Cordless phone and can't remember how to remote access it?
    Using the answering system
    remotely
    Dial your phone number from a touch
    tone phone.
    2 After the greeting message starts, enter
    your remote code (page 59).
    LThe unit plays back new messages.
    LAfter playing back new messages,
    the voice guidance starts.
    3 Follow the voice guidance as
    necessary.
    4 When finished, hang up.
    Note:
    LYou can ignore the voice guidance and
    control the unit using remote commands
    Voice guidance
    During remote operation, the unit’s voice
    guidance prompts you to press {1} to
    perform a specific operation, or press {2}
    to listen to more available operations.
    Operations are presented by voice
    guidance in the following order:
    – Play back all messages
    – Play back new messages
    – Record your message
    – Erase all messages
    – Record your greeting message
    Note:
    LIf you do not press any dial keys within
    10 seconds after a voice guidance
    prompt, the unit disconnects your call.
    LIf less than 3 minutes of recording time is
    available, the unit announces the
    remaining recording time after the last
    message is played back.
    Remote commands
    You can press dial keys to access certain
    answering system functions without
    waiting for the voice guidance to prompt
    you.
    Key Remote command
    {1} Repeat message (during
    playback)*1
    {2} Skip message (during
    playback)
    {4} Play new messages
    {5} Play all messages
    {7} Recording a greeting
    message
    You can download the full manual at
    http://www.retrevo.com/support/Panasonic-KX-TG5776-Telephones-manual/id/1074bh748/t/2/
    Please make sure to rate this solution. Thanks.
    2helpful
    4answers
    New Voice Mail
    I have FiOs and used some of the info I gathered from this page to get my voice mail working now! To set up my voice mail I called my phone number (from the house phone), then pressed * when the automated system picked up...Your prompted to use a 4 digit pass code, which is the last 4 digits of your phone number (worked for me). From there I listened to the prompts and created a new "4 digit pw" as well as a "name password" by the end of the cycle. It then allowed me to listen to the messages on the phone and delete them! Phone finally says ready on it.
    Top NorStar Lands Phones Experts
    Paul Bade
    Daniel Blask
    Daniel Blask
    Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
