SOURCE: Battery Change on T-Touch
there usually is an AC contact point to reset digital watches. Touching the + and the ac point with a conductive wire usually resets the watch. Not sure about the spring- I'm not going to open my Tissot up unless I have to.
SOURCE: Pelican 4300
Send it back to Pelican. They have a lifetime warranty and are one of the few companies that actually stand behind their products.
SOURCE: LED Flashlight Battery Drain Problem
This particular flashlight uses a microchip that consumes the power of the batteries, whether in use or not. Loosen the case to where the batteries go in, so there is no contact with polarity. Or just take the batteries out completely and replace them for actual use.
GGBMDB
SOURCE: Lava Lamp is new, not working, spring loose on bottom, no blobs
The lamp is made of wax and alcohol. Try inverting the bottle several times. The aim is to get the wax to fall to the bottom. Try shaking it, especially when the fluid is warm. This may help break the wax up to where it can begin cycling on its own.....careful, though, you don't want to burn your hand. I have done this several times, and it works!
Best regards, --W/D--
