Question about New Bright 1 8 RadioControlled 96V Red 4Door Jeep
Truck picks up signals on it's own but won't work from controller. As soon as I touch controller, red light comes on and stays on and doesn't turn off until I take out the batteries . Put batteries back in and same thing happens as soon as I touch any button on controller - red light back on & doesn't go out..
  • alstruprichj Jan 03, 2011
    forgot to say - this is brand new just out of the box & charged for 8 hours. Never used & never has worked for us.
Car won't start. it tries to turn over, but just doesn't .battery replaced several months ago so it's not that. The red "GEN" light pops up. Is that the generator signal? Manual doesn&
Interesting. They haven't used generators in over 50 yrs.
But yes that was the warning light for the generator.
If you have a volt meter that would tell you what the system is doing.
If the engine will not crank, and the battery is fully charged, you would need to check the connections at the starter for voltage and ground.
And the red warning lights would normally come on until the engine starts.
Jan 13, 2013 | 1996 Jeep Cherokee Sport
I wired my 1994 van for my camper lights so i could pull my camper. but as soon as i turn the key on.my tail lights come on and won't go off until i turn the key back off
If your van was equipped with a trailer/camper adapter or not, the left turn signal connection is LT GRN/ORG; the right turn signal connection is ORG/LT BLU; the marker lamps connection is BRN, and the stop lamp connection is LT GRN
Oct 23, 2012 | Ford Van Cars & Trucks
My turn signal doesn't come on and the lights
Could be a fuse, the flasher, or the switch. You would need to check for power in and out of the switch.
Sep 16, 2012 | Cars & Trucks
My plymouth breeze won't start, won't make a sound, but my lights and horn still works , help me.
any real answer yet? did the problem ever get resolved? i have the same problem with my sister's car. too cold to diagnose tonight, but will post the solution probably tomorrow. since the lights and heater works, but ignition and radio arent getting power, my first guess is there's probably a fried fusible link which controls the 2nd accessory power to the ignition switch. will post a solution soon.
Jul 17, 2012 | 1999 Plymouth Breeze
My headlights won't turn on, the yellow driving lights turn on but the headlamps won't. Also the lever that controls bright lights doesn't work but the turn signal and cruise control does.
First check the headlight relay by changing it with one of the same number in the fuse panel.If it checks out ok then you have a faulty headlight switch.
Nov 03, 2011 | 1994 Chevrolet Caprice Classic
The brake lights won't go out. I pulled the fuse so the battery doesn't go dead, but can't figure out why they are staying lit.
on your brake pedal there is a switch that controls your brake lights over time it comes to lose just enough for the switch won't come in contact with the pedal
Jul 27, 2011 | 1991 Chevrolet Lumina
6 months ago, replaced head gaskets. 1 week later, service engine soon light came on. Tech said it was an oxygen sensor. Cleared code. 3 weeks ago, got oil change, replaced headlights and replaced...
CHECK TURN SIGNAL FUSE.IT COULD BE BLOWED OR YOU HAVE FAULTY TURN SIGNAL SWITCH.BECAUSE BACK LIGHTS AND TAIL LIGHTS SHARE SAME CIRCUIT WITH TURN SIGNAL SWITCH.
Jun 26, 2011 | 1999 Chevrolet Venture
New Bright 1 8 RadioControlled 96V Red 4Door Jeep Logo
29 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
