Yamaha WX5 Midi Wind Controller Logo
A
Anonymous Posted on Jan 03, 2011
Yamaha wx5 out of tune (1 tone to low) and pitch bend wheel working up but not down...
Fred Yearian
Level 3:
  • Yamaha Master 5,603 Answers
  • Posted on Jan 03, 2011
Fred Yearian
Yamaha Master
Level 3:
Answers
5603
Questions
Helped
2249204
Points
16162
As an electrical engineer, I suspect that one end of the resistance element or the voltage supplied to it is broken. This could be a broken circuit trace on a board or failure of the pitch wheel pot. This is iff the device has a center tapped pot. IF IT DOESN"T (schematics are hard to find on this) then the bias setting for the pitch wheel may be wrong. First thing would be to look if the the wheel has slipped on the control shaft.
What is the best way to reprogram a Yamaha WX5 Ewi
Reprogramming a Yamaha WX5 Electronic Wind Instrument (EWI) typically involves adjusting settings, assigning functions to different keys, or customizing parameters to suit your preferences. Here's a general guide on how you might reprogram a Yamaha WX5:
  1. Access the Menu:
    • Turn on your Yamaha WX5.
    • Navigate through the menu options using the buttons or controls on the instrument. Refer to your WX5's user manual for specific instructions on accessing the menu.
  2. Select Parameter to Edit:
    • Once in the menu, find the parameter you want to edit. This could include things like breath sensitivity, pitch bend range, or assigned MIDI channels.
  3. Adjust Parameters:
    • Use the controls provided on the WX5 to adjust the parameters. This might involve turning knobs, pressing buttons, or using a combination of controls.
  4. Save Changes:
    • After making your adjustments, make sure to save your changes. The WX5 typically has a save or store function within the menu. Confirm the changes and save them to the instrument's memory.
  5. Refer to the Manual:
    • Consult the user manual for your specific Yamaha WX5 model. The manual will provide detailed information on navigating menus, adjusting parameters, and saving changes.
  6. Connect to a Computer:
    • Some advanced customization may require connecting your WX5 to a computer using MIDI. You can use Yamaha's dedicated software, if available, to reprogram certain parameters.
  7. Use External Sound Modules:
    • If you're using external sound modules or synthesizers, some customization may need to be done on those devices as well. Refer to the manuals for your MIDI equipment to ensure compatibility and proper configuration.
  8. Explore Advanced Settings:
    • Depending on your proficiency and the complexity of your WX5 model, you might explore more advanced settings like custom MIDI mapping or adjusting sensitivity curves.
Remember to approach reprogramming with caution, especially if you are not familiar with all the settings. Make note of the default settings before making changes, so you can revert to them if needed.
Always refer to the user manual specific to your Yamaha WX5 model for accurate and detailed instructions on reprogramming and customization. If you're unsure or uncomfortable with the process, consider seeking assistance from Yamaha support or experienced professionals in electronic wind instruments.
How do i fix a Yamaha P95 that sounds Es with Fs and Bb with Bs across all the octaves?
Whether it happens to all of the key?
If yes, transpose setting may have changed. Change the setting to normal (0).
If the normal transpose, but tuning is still not standardized, check Pitch Setting.
To Restore Standard Pitch setting:
Hold down the A-1, B-1, C0 and C # 0 keys simultaneously and press any key between C3 and B3.
View image :
fix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-0.jpgfix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-1.jpg
If the above procedure is still no effect, try resetting the factory settings / Initialize overall: :
This is the steps:
Initializing the Settings
When you initialize the settings, all backup data stored to this instrument will be initialized and reset to the factory default settings.
Turn off the power to the instrument. Then, simultaneously hold down the C7 key (right-most key on the keyboard) and turn the power on again.
NOTICE
Do not turn off the power to this instrument while it is initializing the data in its internal memory (that is, while the button indicators are flashing).
View image:
Notes:
If this instrument somehow becomes disabled or malfunctions, turn off the power to the instrument, then perform the initialization procedure.
With no octave keys pressed the wx5 is playing an octave too low
Please have a look at the instruction manual again. The 8ve keys are assignable/editable for up or down. You can change the range of the scale this way. I own a WX7 and a WX5. They both work this way.
Wx-5 interupts sound / chopped off sound
Please consult your manual again. The velocity and breath pressure are adjustable. The procedures and location of the switches and potentiometers are described in the manual.
Ewi and vocoder setup
hi, i have a YAMAHA WX5, and want to know if it's to use a Vocoder?
Mike Phillips is the same, or if it only works with the EWI 4000s?
and as a connection is made?
thank you!
Can't get the guitar tuned
Tell her to tune all strings below the pitch and always go up to the pitch, never down because of slack in the tuning keys. The gears will have a slight bit of play in them. If coming down and stopping at the right place, they will loosen and loose tuning when she lets go. Tuning from below and go up to the pitch will correct that. (more noticeable on electric) Also, I would take it to a shop to have the intonation checked and tuned if necessary.
Notes out of tune
No, but the pitch bend control can do that.
1helpful
E5 flat and off pitch
Inspect for damage, especially hairline cracks. Also inspect for contamination or dirt that will change the resonant frequency. AND VERIFY the tuner you are using is accurate. Do not compare to a piano which MAY be out of tune... in fact, pianos are STRETCH tuned, that is the higher notes are SHARPED and the LOW notes are FLATTED deliberately. Comparing your chimes to a piano, the E5 would appear flat. Use a good electronic tuner to verify the pitch, not a piano,
I can't get my Yamaha WX5 to sustain, or play more than one note. I got it to do it long ago by accident, but can't seem to get it to do it again. I think I was using a Yamaha Keyboard for the sounds at...
Reread your manual pages 14 and 15. Note page 14 tells you that "When using a monophonic tone generator such as the VL70m, the Normal Hold and Follow Hold functions CANNOT be used." I have both the WX5 and WX7. I also have both the VL70m and the WT11. The VL70m has a lot of better sounds, is editable and has better effects the WT11 allows you to use both follow modes. Any polyphonic midi keyboard with a midi in jack will allow you to use the follow modes. Read the directions on page 9 of your WX5 manual to hook your WX5 to the keyboard. Set your keyboard to receive all midi channels. I think it is Omni On, Poly. Hope this helps.
1helpful
My tyros 2 has fallen down very bad.now the left bass octave is off pitch(half note Higher) when i play the keybord with the accompaniaments.It works right ONLY when the ACMP is disambled what can i do....
Likely you have damaged the pitch bending wheel and offset it.
Try to pull it on pitch with the wheel... IF YOU CAN, then the alignment of the detent of the wheel has been disturbed and unit will need servicing... There are a lot of screws to open this and several very tender cables that can be damaged... I would recommend you take it to a shop experienced on this keyboard.
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
