Hi there.
see if this link helps you find out why.
Router Keep shutting down and rebooting Google Search
SOURCE: Router rebooting?
Try the following...
If these are not the issue then there is possiblity of device failure.
SOURCE: D-Link Wireless Router WBR-2310 no reception
There can be a problem with the router, first thing that you can do here is to reset it by pressing the reset button of the router for 30 seconds while the power is ON then after that unplug the power of the router for 10 seconds and if you still have the setup CD you can just run it to your computer to reconfigure the router back but if not you need to manually configure the router and also do a firmware/software update for the router and if you're not familiar that you can contact this number so a tech can wlak you through with the process of checking the router and making it work again, this is the number that you can dial 1-877-787-8749 for help......
