Apple MacBook Air Logo
Posted on Jan 02, 2011
Help me please i tried resetting the admin password on my macbook air without the disc i looked it up on the internet and i did what it said i typed in theses codes then it wont start up at all please help someone.
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Jan 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
3768
Points
20
I suppose you have a l&te 2010 Macbook Air... - Plug the Macbook Air to a power outlet
- Plug the Macbook Air USB software reinstall drive that came with your Mac (in the little black cardbox) in any USB port - After the initial screen, go to "Utilities" in the menu bar and then choose "Reset Password" - Follow up the process and you should be OK.
Hope this will help. Cheers.
1helpful
3answers
Reset my apple password
It depends on the OS X version, but Apple's instructions for Snow Leopard, and previous, versions, are described or linked at OS Changing or resetting an account password Snow Leopard and earlier
However, the easiest route would be to contact the eBay seller for the password that they set.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
Can't sign in + can't change password
to reset without any admin passwords, you'll either need a boot disk or use command line to reset the admin password
4answers
I forgot my windows 7 admin password how can i reset it without a flash drive or disc
u have to remember your password. no other way. if you have genuine os, ask microsoft.
1helpful
2answers
How do i bypass macbook air master password without a disk
Maybe the owner's manual might make reference to some sort of reset option. If the password is a simple 4 digit code, then guess it. Most peoples' passwords have something to do with the person who set the password, I.e. a nickname, name of a family pet, anniversary date, etc.
2helpful
2answers
I forgot my password for my macbook
Here’s how to create an admin account without knowing the current macbook administrator password.
Help with reseting root passwords
If you have the discs available that came with the Macbook you can use the utility on them to reset the password. 1. Reboot insert the disc and hold the C key untill you get the welcome screen. 2. Click on the language you prefer and proceed as though you are going to reinstall the software. 3. At some point you will notice the menu bar at the top. Click on the drop down menu for utilities and you will find "Reset Password" If you do not have the discs available you can also use terminal to create a new administrator account and then reset the password. To do this 1.Reboot 2.Hold down the apple and S keys after you hear the chime. 3.At the text prompt enter these commands following each one with the return, • mount -uw / • rm /var/db/.AppleSetupDone •shutdown -h now
reboot and you should have a new admin account
2answers
Problem entering router password
Try going in though its IP address to setup. In internet explorer, type in (with nothing else - NO http - NO www) just type: 192.168.1.1 - then use
username - type admin
password - type admin
That should get you in without using the cd software.
4answers
Windows vista admin password
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
