SOURCE: message indicator light on Uniden PowerMax 5.8ghz handset
I'm having the same problem, too. However, the beeping continues and continues. Even when it stops, the light comes back on. Any other thoughts?
Blinded by the light
SOURCE: The flashing light on phone
Press down the "find handset" button until the paging beep stops (about 5 seconds) and this will reset the indicator lights on the handsets.
SOURCE: a red light at the top left hand corner of the
It might be your voicemail. Check your voicemail.
SOURCE: I have a new Uniden cordless phone. The handsets
You can downlaod the manual from uniden in pdf form.
http://www.uniden.com/products/productdetail.cfm?product=DECT1580-4
the -4 or -5 refers to how many handsets you set. The 1580 is the actual model number.
To register I think all you do is place them on the master pad once then on their own charger stations. On some models they come all done so you just plug them in charge them up and use them.
SOURCE: indicator light won't stop flashing
I have a Uniden 5.8 GHz and the message indicator light will not stop flashing. The phone screen says I have a voice mail but I don't. Does anyone know to fix it?
