Alps MD 1300 Thermal Printer Logo
A
Anonymous Posted on Jan 02, 2011
Printer only prints the middle of the text, leaving the bottom and top part blank
foursaleoncr
Level 1:
New Friend:
  • Contributor 83 Answers
  • Posted on Jan 06, 2011
foursaleoncr
Contributor
Level 1:
New Friend:
Answers
83
Questions
0
Helped
21203
Points
95
Try changing cartridges to see if you have the same problem. Also, try a good cleaning of the print head.
Labels not lining up corectly
Go to printer options and select "Fit To Page"
My printer is leaving a blank line through text
Please use original cartridges to solve the problem.
1helpful
Only prints on bottom half of label.
Your scanner and thermal printer has got loose connection. Print head also may need cleaning by own system. try from the software.
JMC
Small text and screen blank top and bottom
try to replug the lcd connectors. you have to dismantle it
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Lexmark Z53 Prints Lines
please clean wast toner tank it have under photocoductor
Won't print text from center of page
chekc oyur ink crtidge also check ink tank.
there issue of ink.
Top Alps Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
ADMIN Andrew
ADMIN Andrew
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
