Question about Razor E100 Electric Scooter
The back wheel of my sons scooter has stopped moving
    New Friend:
    Problem Solver:
  • 15 Answers
Then kick that lil **** in the face or unscrew its vold and clean out its rust
Posted on Jan 02, 2011
SOURCE:
I charged scooter and it still won't move back wheels seem to be locked up
that's normal the wheels r locked if u moved the free wheel lever check to c if its back in lock position if it is and the scooter wont move it might b an electrical problem check to c if its got a reset button ....good luck
Jul 02, 2015 | Health & Beauty
Stopped going when free wheel lever accidently pushed forward. Put back. Still wont start.
Check for error codes. Move free wheel lever in and out a few times in case the brake micro switch is not making correctly.
Check speed control is not turned down low.
Mar 21, 2015 | Pride Celebrity X 3 Wheel Scooter
Scooter troubleshooting
Download the service manual from Pride's website. It has all the answers.
May 07, 2014 | Pride Mobility Revo 3 Wheel Electric...
Go Go scooter wont engage gears
Try first without power to switch from freewheel to engaged. Its usually a small lever on the back by the wheels. If the scooter can be moved by hand its in freewheel. Switch the lever then move the scooter slightly til you hear it click in. They don't have brakes, They are supposed to live in gear and then are either moving or not. :) Hope this helps.
Oct 16, 2013 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
We have fully charged the battery but when we pull the paddle to move it doesn't go
Reengage the wheels again then give it a slit push you should fell some resistance .seems the freewheel is not fully in
Apr 24, 2013 | Electric Mobility Mobility Electric Power...
My Lynx L4 4-Wheel scooter green light flashing but it said it is charge it wont go forward
the green flashing light indicates an error with the scooter. Count the number of flashes 4 flashes pause 4 flashes pause etc and your manual should give you the meaning of the flashes Check to make sure that you are not in freewheel move the lever at the back of the scooter up and down a few times and make sure you leave it in drive mode turn on the power and see if the light stops flashing and the scooter will operate correctly Hope this helps
Oct 03, 2010 | Activeforever Lynx L4 Portable Mobility 4...
I have a gogo scooter it bleeps once than cuts out I have to turn it off and back on for it to move
probably a dead battery or a bad battery will move you till the controller gets to a threshold voltage then it beeps and stops , testing this is easy turn on the scooter adjust the speed control to the lowest setting then start riding the scooter at full throttle then start turning up the speed controller if that produces the problem then the batteries need charged or replaced
Jul 01, 2010 | Pride Mobility Products Go-Go Elite...
Pride Celebrity 3 wheel. The free wheel lever
My Mother buggy does the same and you can damage the gearbox, so I use a elastic try down to the bumper this stops it from moving but should there be a need I can remove it.
the Freewhel mech may have come loose so check it out.
Regards
GeWiz.
Oct 12, 2009 | Pride Celebrity X 3-Wheel Electric Scooter...
Battery power on mobility scooter
Most scooters show a drop on the battery level meter when in use, as long as it is`nt slowing down it should`nt be a prob. I mean,when you engage the throttle you ARE putting a load on the batteries,so it`s only par for the course that the indicator would drop a bit.
Jan 04, 2009 | Pride Mobility Products Pride Mobility...
Razor E100 Electric Scooter Logo
142 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
ROB
Are you a Razor Toy Expert? Answer questions, earn points and help others
