I have a 2003 Nissan bakkie. It appears the fuse box may be wet. The vehicle started once and then died. Lights don't work or windscrren wipers. The bakkie was left standing for two weeks and there has been heavy rain nearly every day. The battery is fine. Could the fuse box be the problem?
You should check out www.reliable-store.com they have info on repair, service, wiring diagram, electrical diagram, fuse diagram, torque specs, troubleshooting, PCV, gear box, owner's/service/repair/parts manual, fault codes, error codes, etc everything on all vehicles. must check it out
With IPDM - intelligent power distribution module . Pull the front wiper relay and front wiper hi relay , see if they reset . If that doesn't work you'll need to take it to the dealer an have them reset with factory scan tool . Also ,sometimes new modules need to be programmed . Download 2003 Nissan Altima Wiper Washer Section WW PDF Manual 36 Pages
Sounds like a bad fuse. There are fuse boxes under the hood as well as inside. Try swapping the same number fuses with each other. If what you swap for starts working replace the fuse you swapped with. Alot of times there is a fuse puller in fuse box case and spare fuses.
sounds like you need to start by checking fuses. there are panels on the ends of your dash on both driver and passenger sides. there are also two fuse boxes under the hood that are essentially your main fuse block. there is a BCM...or body control module...but i would start with the fuses first
There may be a seperate fuse for that feature. The thing to try is find the fuse box. It is generally under the left hand side of the dash on thedriverside butthey have been known in some vehicles to be on the right hand side under the dash and even inside the glove compartment. There are some models that setup the fuse box under the hood as well. If you have an operating manual with your vehicle then the fuse box will be located in there.
Once you find the fuse box then try thist rick.
Locate instrument panel fuse. In this case there should be two with instrument panel listed but if not then it may be all in one fuse. What I woulddo is just turn thekey on so the lights you want off are shinning on so you can see them. Then one by one pull a fuse. If thelight stays on then replace the fuse back in the same spot you took it out of, Continue doing this one fuse at a time and replacing it back in the same spot until the dash lights go out. Then see what the fuse box says about that certain fuse and what all it operates. It may be that you can not disable the dash lights this way without disabling something else you need such as a blinker or heater or radio, but what I am hoping is it has its own seperate fuse. If you arenot sure what it operates by what it says onthe fuse box then once the fuse is out start the car and check all of your other lights including brake lights and blinkers and of course thedash lights that work when your head lights are on. Check all of yourother switch operated devices like the radio and windsheild wipers and heater. Anything that has a switch you can test. Remeber that you may have pulled the fuse that operates the dashlights but there still may be another fuse that operates the dashlights you want disabled, so if the fuse you puilled disabled stuff youneed then replace thefuse and keep pulling more until the dashlights go out again or you run out of fuses to pull. Remeber to turn the headlights back off while you arepulling more fuses. I hope this was helpful, Raz
