Question about La Crosse Radio Controlled Atomic Clock
I have a La Cross Radio Controlled watch Model WT 961(S). Its time display went blank on New Years Day. I press the little side button, and all it does is show 12 hr or 24 hr options with DTS On or off. No other options appear. What shall I do ?
4 Suggested Answers
SOURCE:
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
Posted on Feb 17, 2008
  • 2501 Answers
SOURCE: How to set a La Crosse radio controlled watch
Go to http://www.lacrossetechnology.com/support/setup.php and choose your watch from the drop down menu.
Unfortunately they do not have any instructions but there is a contact address there where you can get help.
Posted on May 09, 2010
dunnbiker
  • 8546 Answers
SOURCE: It looses time and the radio controlled feature
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Posted on Jan 25, 2011
Hands rotate endlessly onatomic clock wt 3143
If you have not talked to La Cross and if you continue to have the problem, most likely it may be a signal problem. I had a similar
problem with an earlier model and found that it only worked on
the west facing wall as the signal is coming from WWVB which is the NISTtime signal radio station near Fort Collins, Colorado. Get a fresh battery, reset the clock, put it in a west facing window and leave it overnight. If it doesn't work, contact La Cross as above post.
Dec 12, 2014 | La Crosse Radio Controlled Atomic Clock
How to set a La Crosse radio controlled watch Model # WT-961(S) 12-24
May 09, 2010 | La Crosse Radio Controlled Watch
Manual for La cross technology radoi controlled digital watch #wt
Downloaded instructions and working on it.
Thank you.
Bernard W. Goering
Sep 12, 2009 | La Crosse Radio Controlled Watch
Replacing battery
Go to this site below and print out the manual. It gives their recommended way of doing it. If that doesn't work, it even gives a phone number to call and email address to write to..
http://www.lacrossetechnology.com/967s/manual.pdf
Jul 30, 2008 | La Crosse Radio Controlled Watch
Adjust the date and day on a festina 3 dial watch
I've just worked it out! Change month....depress inset button on side above hand winder. One push with cocktail stick or similar will advance month. Change date.....pull out hand winder half way, turn knob anti-clockwise until desired number is met. Change day...... pull out hand winder fully, turn clockwise passing midnight repeatedly until day is set, continue to set time, keeping an eye on 24 hour display for am/pm.
All the best, Bob
May 06, 2008 | La Crosse Technology E. Howard Ambassador...
How do I set a LaCrosse WT-961 (B) watch?
This watch automatically sets itself. I you live in the eastern time zone, you just have to wait for the watch to receive the signal then it will set itself to the correct time & date. The signal is strongest at night between the hours of 10:00 pm & 2:00 am so it normally takes over night to set. Sometimes the weather interferes with the signal so I tell people to give them a couple of days to pick up. Also if you are having trouble receiving the signal try placing the watch by a window. If you do not live in the eastern time zone try these instructions:
Hold down the button for 2 seconds until the time zone abbreviation & zone flash the keep pressing the button until your correct time zone is displayed. Then wait about 8 seconds for the watch to return to normal display. Then you just have to wait until it picks up the signal & sets itself. I hope this helps.
Mar 07, 2008 | La Crosse Radio Controlled Watch
Oct 17, 2007 | La Crosse Radio Controlled Atomic Clock
La Crosse Radio Controlled Atomic Clock Logo
234 people viewed this question
Top La Crosse Home Experts
Steve Allison
Steve Allison
Are you a La Crosse Home Expert? Answer questions, earn points and help others
