2003 samsung HLN5065w DLP TV was replaced with Philips lamp 6-month ago and worked well. Two-week ago I turned on tv and showed picture with sound lasting 15-second. Then TV automatically turned off and three LED lights blinked. I can not turned off TV with remote control. The only way is turning off power strip. I send lamp to supplier lab for checking and they said lamp is good shape. Now I turn on TV and screen shows white and black dots without picture and sound and it lasts only 8-second then TV turn off automatically. No any noise sound is heard.
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Sounds like the Lamp is over temperature. Either the fan went out or the filter is clogged! You might check the filter first. I hope this will help you...
Sounds like the old lamp blew and took out the ballast. I believe that you need a new ballast for your unit. The other possiblity would be a problem in the low voltage power supply but if the indicator lights are blinking the most likely problem is the ballast.
Yes,the problem is the colors wheel it dead.That one of the cause by the colors wheel,other are alots of squiling noises and making very loud buzzing sound.The cooling fan that u think is overheating,does it stop sometimes,when the tv is still on?Yes,than replaced it also,no than it still ok.Just hire the tv repairman,the parts he'll take care of it,don't order the parts,u might get the wrong parts or different sizes,that will not fit in ur tv.
I had this happen a few months ago. More than likely the color wheel died. I opened up the back of my Samsung DLP expecting to find a blown lamp, but came to find out that only the color wheel was in need of replacement.
