SOURCE: water is dripping inside refrigerator
This ia a common problem that indicates the drain from freezer is clogged or blocked. I will send you to another link to help explain how to resolve this, Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
SOURCE: water in bottom of refrigerator
the drain tube for the defrost cycle is plugged,somewhere in the back of the refrigerator inside ,usually toward the top depending what kind of refrigerator,will be a spot where the water drips into a little funnel or trough that leads to a line that runs out the back of the refrigerator and down underneath to a tray ,i use a bicycle cable to clean it out.if you remove the grill under the door by the floor ,you should be able to pull out the tray and see if its wet,usually every 10 to 12 hrs or so is goes through a defrost cycle the water collects in the pan underneath and evaporates
SOURCE: water leaks from inside refrigerator
could be ice is forming at the vents already.
even though it is a frost less refrigerator, in some instances, you may want to defrost it manually or leave the door open for 1 day just to be sure that every ice in the fridge has melted. then plug it back in and observe it.
tnx 4 using fixya,
drcool
SOURCE: water leaks into bottom of refrigerator
defrost drain was clogged , unclogged drain solved your problam
SOURCE: There is water collecting inside my refrigerator.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
