Question about Sony Ericsson XPERIA X10 Cell Phone
Hi, My xperia constantly restarts by itself. Whenever, I use the internet or use some application, the phone just restarts by itself. I have tried to upgarde, but the issue is worse now. The phone cannot be used until you remove the battery, sim, memory card, and wait four about 5-10 minutes.
SOURCE:
SOURCE: turn the phone on and keypad lights but nothing else happens
well... I just reinstalled the firmware... with the update downloadable program... and it worked but I don't know for how long
Posted on Oct 01, 2009
SOURCE: cannot use phone function on x10
i have exactly the same problem it is happening to me as it occurred 4 days ago just happened when trying to call it just say call ended and cannot receive and send calls or texts either.
signal strength is full i have hard reseted it and done almost everything my x10 is on orange and i cannot thing of a solution for the problem i go it online and cannot get return it to anyone when i revived it, it was fine its just happend i hope there is a solution because i love the phone.
Posted on May 20, 2010
SOURCE: unable to connect to the market it say sim not
registration failed
Posted on Sep 30, 2010
SOURCE: My phone is sony ericsson xperia x10 mini pro, i
My phone is sony ericsson xperia x10 mini pro, i have kept it for charging after few minutes red color light is blinking and it is not turning on, i have tried removing battery, sim and memory card, but still th problem is same. please help me
Posted on Oct 26, 2010
  • 133 Answers
SOURCE: I am trying to copy my contacts from my Sony
When in the phone book:
Press the menu button (far left) > More > Back up contacts > SIM card
Posted on Dec 25, 2010
Sony xperia t troubleshooting
restore settings
or this one note all data will be deleted
How to Soft Reset or Reboot or Restart SONY XPERIA T LT30p ?
To soft reset SONY XPERIA T LT30p, press the POWER BUTTON KEY for several seconds, we will see the menu to restart or turn off. Choose restart/reboot than the SONY XPERIA T LT30p will do the soft reset or restart. This is safe to do because non of important data or applications will wipe or erase.
#Option 1, Hard Reset SONY XPERIA T LT30p with Software Menu :
  1. Make sure the battery is charge properly
  2. Turn on SONY XPERIA T LT30p smartphone
  3. Don't forget to backup all important data
  4. Go to menu: Setting > Backup & reset > Factory Data Reset > Erase internal storage > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA T LT30p
  6. The SONY XPERIA T LT30p will continue the step until ready to use in clean factory default.
#Option 2, Hard Reset SONY XPERIA T LT30p with Flashtool applications:
  1. Flashtool in the applications from Sony can be download from Sony website.
  2. Flashtool software need to installed in you computer and ready with USB data cable
  3. Make sure SONY XPERIA T LT30p battery is charge properly or full charge
  4. Power off SONY XPERIA T LT30p
  5. Boot SONY XPERIA T LT30p to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
  6. Follow the menu at you computer display, it is easy to understand the steps.
#Option 3, Hard Reset SONY XPERIA T LT30p with Hardware Key Button:
  1. Make sure the battery fully charge
  2. Do not forget to backup all important data
  3. Turn off the SONY XPERIA T LT30p
  4. Press and Hold together: Power Button + Volume Up Button for several seconds
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA T LT30p
You can choose the step options above to do hard reset while the SONY XPERIA T LT30p get problem or not running well. But we always suggest to do routine backup before your smartphone get problem. If SONY XPERIA T LT30p already stuck or run slowly or not responsive, then better try to do backup as you can because all important applications will be wipe or removed from SONY XPERIA T LT30p after doing master reset, but some data which saved at memory card will be safe, better to remove the microsd memory card before doing the hard reset.
Jun 16, 2014 | Cell Phones
Why does ST21i2 restarts itself
Restarts on Android happen sometimes just like with any other OS(windows,etc.) if it constantly restarts itself(Bootloop) then try a factory restore.
May 06, 2014 | Sony Xperia Tipo Dual ST21i2 Black Android...
Forgot passcode lt30p
Mar 05, 2014 | Sony Ericsson Sony Mobile Xperia T LT30p...
Can i install radio on my xperia x10
Hi andyss651, The Xperia X10 does not have a radio tuner, so you cannot listen to radio via radio tuner. If you want to listen to radio on your phone you could use an application called shoutcast or go to last.fm and listen to radio over the internet as long as you have a data plan. Alex
Jun 04, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Hi, how to remove application at internal phone memory. my phone is sony ericsson xperia x8. Thanks...
If the application is pre-installed and you can't un-install it via your "Applications"option in settings then the only way to Un-Install it is to first ROOT your handset
Then Download something like "Titanium Backup" From the "Market"
Due to the length of the process on how you "Root" your handset and the Problems that may arise "During" the process and also the fact that "Rooting" your phone voids your warranty. All I can do is tell you to check out this LINK and read up thoroughly before attempting it.
The software itself is simple to use and is used for other Experia handsets so don't be worried if it doesn't mention the X8. :)
Mar 10, 2011 | Sony Ericsson XPERIA X8 Cell Phone
Hi, I have a Sony Ericsson K790i phone and have recently bought a Xperia X10. I want to copy my contacts from K790i to my new X10 without using the internet. Please help
you have net connection pc system,so easy change contect first you download for latest pc stiute for sony.k790i mobile connect to systems you see the new icons for systems right side down place,open for icons right now you see some applications tools,editors&applications.if you double click for editor open to flies,text massages,contacts&calendar.left side you see the applications full view just capy to paste for systems.next you same connect x10,contact system to paste moblie.
Nov 22, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Java Applications fail to execute
You need to download and install Java for phones. maybe Flash Player too, in fact get all add on's and plug in's.
www.adobe.com/products/flashlite/ - United States
www.javaphone.it/en/
Apr 04, 2010 | Cell Phones
Not enough resources - Samsung Jet
I just restarted the phone and it worked again. Simple as that
Jul 08, 2009 | Samsung Cell Phones
Sony Ericsson XPERIA X10 Cell Phone Logo
57 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
