panasonic SC-HT830V will not open the DVD . It says Locked. Does anyone know what I can do?panasonic SC-HT830V will not open the DVD . It says Locked. Does anyone know what I can do?
Same problem, I have a Panasonic SC-DM3... it seems like a "Child Lock" so that the DVD tray won't open.Same problem, I have a Panasonic SC-DM3... it seems like a "Child Lock" so that the DVD tray won't open.
I had the same problem. I found these instructions to unlock it. It worked for me. Good Luck!
Unplug the DVD player for 30 seconds.
Turn the DVD player on WITH THE REMOTE.
Press Enter on the remote.
Press 8, 4, 2, 6, 9.
The Tray is suppose to open automatically after doing the above. Mine didn't. I pressed the open button on the remote and it opened.
Depending on your sytem, press the stop or pause button while system is!It's in the manual
On the center unit ONLY:
While the system is turned off
• The system turns on and “LOCKED” appears on the display
window.
• If you try to eject the disc, “LOCKED” appears to indicate that
the tray is locked.
To cancel
Carry out the same operation again.
• The system turns on and “UNLOCKED” appears on the display
hello
Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
The Disc Tray is Locked
If the message “Tray Locked” appears on the screen, the retail lock feature has
been accidentally engaged. To unlock the disc tray you must press and hold a
combination of keys simultaneously:
On the front panel of the DVD Player, press and hold the STOP, ON•OFF and
OPEN•CLOSE buttons for at least 3 seconds.
I forget the password Your player is equipped with a “back-door” unlock sequence. Press and hold
the STOP button on the front of the DVD Player and the STOP button on the
remote control at the same time. (Hold both buttons down at the same time
for at least 3 seconds).
Do not have better news. You can unscrew the player, and see if dust is stuck in the gear that controls the dvd opener, or check the online dvd repair guys. But, really, it is cheaper/less of a hassle to get a new one.
Hey I just found out how to UNLOCK the tray Power up the unit, wait for it to read the disc if one is inserted. hold the stop button and the power button down together for 5 seconds the display will show UNLOCKED Open/close button should be restored
To unlock, manually press and HOLD the open/close button & the stop button simultaneously, and HOLD them both down until the lock picture disappears. The DVD will eject when you press the open/close button.
To lock the DVD inside the machine, repeat the same step, and it will lock it inside.
tray will not open - says locked jvc TH-S55
has anyone held, i´ve the same problem
'Tray Lock' error message... Can't eject CD.
tray is not opeaning says locked
says 'locked' when i try to do anything with the dvd functions.
