SOURCE: rca remote control code list
unfortunately i do not have a code for that specific model, you can however try the automatic code search method.
1) turn on the dvd player
2) press and hold the code search button, when the indicator light is lit, release the code search button
3) press and release the component button you wish to use (dvd), the indicator light should blink once and remain lit
4) aim the remote at the dvd player and push the on/off/power button, there is a 3 second pause between codes, so keep the remote aimed at the dvd player
5) as soon as the dvd player turns off via remote, press and release the enter button
now to record the code for future reference..
1) press and hold the code search button, when the indicator light is lit, release the code search button
2) press and release the component button you wish to use (dvd), the indicator light should blink once and remain lit
3) press and release the code search button, the indicator light should turn off
4) starting with 0, press and release each button in numerical order (0-9) until the light blinks, write down the number that caused the light to blink
repeat step 4 two more times until you have the 3 digit code. in the future you can use the direct programming mode to reprogram the remote if need be.
hope this helps,
trin
SOURCE: Programming Code for a Toshiba dvd/vcr on a Samsung BP59-00048 universal remote control
If you haven't found the manual yet, you can download it from samsung.com's download center. Just enter your model number or search by product category.
SOURCE: JENSEN UNIVERSAL REMOTE
i have a tv sylvania but i lost my codes for jensen universal 5 remote control ...
need desperate help
SOURCE: i need the codes for jenson remote JER 323
NECESITO EL CODIGO PARA MI CONTROL REMOTO JENSEN JER323 PARA UNA TV SONY
