Clean the drain pipe line remove some foreign object inside the line that coz of blocking water going out,if clean but water not going out you need to replace the drain pump of your unit.lay down the unit check the small motor that connecting to drain line remove the screw and remember the exactly position of the parts before removing,after that buy a new one and return properly and carefully.,remind unplug the unit before anything to do.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
