GE WSXH208A Front Load Washer Logo
Posted on Jul 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Timing is off
I have a GE front load washer that walks and says that there is 10  minutes left but really takes 20 to finish.   What will GE do about the walking and has anyone had the same problem with the timing?
Anonymous
Level 3:
Genius:
  • Master 1,028 Answers
  • Posted on Jul 09, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1028
Questions
Helped
316758
Points
2631
Timing is not the probelm off balance load or washer not solid on floor is...front load washer try to balance load as much as possible before full speed spin the 10 min is only and est ..additional time will will be taken trying to balance load and no ge won't do anything about the walking best try getting machine as solid as possible if on pedistal good luck..lower bottom as close to floor as possible both rear legs all the way up adj front legs for solid setting try rocking washer and adj legs till solid..also weak floor?
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Why does my Kenmore HE3t front load washer always take more time to finish then what it says on the timer?
Check the filters in both ends of the hoses. If they are clogged, it will throw the timer off. If it figures on 2 minutes to fill but it actually takes 6 or 7 minutes, the timer won't be accurate.
Kenmore HE3 2plus wont finish cycle
I'm not saying you don't have a problem. But just to be clear. You do understand that the last minutes on these machines can vary. The machine senses certain conditions in clothing, water discharge, etc. So sometimes the "1 min left" indication can stretch into many minutes. In theory, at least, it's possible your machine just needs to be left alone until it finishes whatever it's doing. However, one would think that any issues not resolved in 10 - 20 min are an indication of a problem. So i guess that's my next question, did you wait long enough? Keep in mind i am not a kenmore expert.
1helpful
2answers
When the timer gets down to 1 minute left and the machine is on the spin cycle, it takes another 10-20 minutes to finish the cycle. The total 40 min. cycle takes over an hour to complete. Does anyone know...
The timer is only an estimate. pull the botttom cover of the front of the machine. There is a cleanout on the water pump, if its clogged it could be the cause of your timer taking so long
9helpful
2answers
Washer stops w/ 19 min. left to finish and door pops open.
the same thing happened to our washer and a friend told us to take off panel below door and there's a opening that's covered with a circular plastic cover, open manually and remove all the junk that's accumulated from all washes, careful it may leak a great deal of water! Try that if anything else, unless you've already had it serviced!
I'm looking to try and solve yet another issue with the same washer...
3helpful
2answers
I have a GE WBVH6240HWW Front load washer. I
i would try to clean the trap out at the bottom, there is a panel on the bottom take that off and clean out the trap, it looks like a turn dial, something like that has happend to me, it cant hurt to try
Ge washer making clicking sound
Hi, I don't know the model, but it's possibly moving the water fill nozzle over the Fabric Softener compartment in the soap drawer.
Clicking is normal for that.
5answers
WBVH6240HWW
It is under Warrty call GE to come out dont mess with it as long as it is under Warrty
Ge front load-
We had the same scenario, only our clothes were still very wet when it finally finished the cycle. To cure all three we cleaned the filter behind the front panel. It was badly plugged and it, and the water it was holding up, smelled foul. So far so good since.
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
