Sewing Machines Logo
Posted on Jan 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need threading guide manual for mod.575FA - Necchi Sewing Machines
Debbi's Sewing Machine Repair
Level 3:
  • Necchi Master 7,365 Answers
  • Posted on Jan 03, 2011
Necchi Master
Level 3:
Answers
7365
Questions
Helped
1744286
Points
19451
Sewusa.com has threading diagrams
How do I thread hobby grand quilter 1200
The Hobby 1200 is a Pfaff sewing machine that they call the Grand Quilter. First raise the presser foot and make sure that the needle is at the highest position (press the needle up/down button twice with the machine on). Then turn off the machine and unplug it for the maximum safety. For the top thread, place a spool on the spool pin and guide the thread through one of the two thread guides on the thread guide bar. The thread starts from behind the guide. (The post holding the guide bar is next to the spool pin.) As with most sewing machines, you will work from right to left and lead the thread down then up before going down to the needle. Bring the thread to the next thread guide (in front of the bobbin winding pin) and pass it through one of the holes from the back. Wrap the thread to the back of the guide and then through another of the holes. If the thread tension is very loose, try going through all three holes. Bring the thread down between the pre-tension discs going counter-clockwise.
Hold the thread in both hands and guide it around down and around the tension dial from right to left. Bring the thread up to get it between the tension discs and behind the tail of the check spring. Bring the thread back down over the loop of the check spring then under the thread guide that looks like an upside down L with a curve in it. Bring the thread up and through the next thread guide. (This guide is horizontal and just above the previous guide and one side ends near the center of the tension dial.)
Bring the thread up and pass it through the eye in the thread take-up lever and then back down through the horizontal thread guide above. Slip the thread into the thread guide and then down to the needle bar thread guide. Thread the needle from front to back. The thread should be along the groove in the needle.
You can find the manual at Pfaff's Machine Update page: http://www.pfaff.com/en-US/Support-and-Updates/Support . Search for the model and then you'll get to the product page: http://www.pfaff.com/en-US/Support/3336 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/GrandQuilter-manual-EN.pdf . The threading section starts on page 21 (page 23 of the PDF). The manual has good pictures that are better than my attempts to describe the guides.
I hope this helps.
Necchi 575FA how to put the bobbin spool in the case?Bobbin mats up with a lot of threads on the bottom stich.
The problem most likely is not the bobbin. The problem is the top thread. If thread is knotting, tangling under the fabric, it is a top thread problem.
Remove the top thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning.
If there are still thread clumps under the fabric, you will need to increase the top tension. (The extra thread appearing under the fabric is excess top thread hanging up under the fabric.) You may need to keep adjusting the top tension until both top & bobbin threads meet in the middle of the fabric.
1helpful
2answers
Need a Nelco sewing machine mod 4102F manual.
  1. http://www.sewusa.com/index.htm try finding it on this website. maybe you will get lucky.
1helpful
3answers
I need a manual for a JCPenney Model 6601. Or at least how to thread it.
Back in my 7th grade home ec class (I'm 52 yo now), our teacher told us that all machines thread basically the same and I never forgot that and it has served me well through the years. No matter what brand of machine, or level of machine (from little girls first one, my embroidery or my heavy duty industrial leather machine) they have all threaded the same:
Thread spool
thread guide
thread guide
tension
take up lever
thread guide
thread guide
needle
(the number of thread guides may vary)
Best of luck and happy sewing!
I have a Necchi 575FA and the bobbin thread cloggs up.
try changing the needle
also try using a different bobbin just incase there is something
wrong with that one
make sure the thread is wound evenly on the bobbin or this will
cause problems
make sure the bobbin is turned the right way in the bobbin case
2answers
Necchi 575FA runs heavy, wheel barely turns.
It is the bit that rotates the bobbin case back and forth in a "shuttle" motion.
It sounds like it would be worth exploring the idea that it is time for a service !!
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
