You are correct if you overtighten the bolts the tank will crack.
They make rubber spacers that go between the tank and the stool, that can be put in to help the part of rocking or wiggly, try that.
with your toliet making a crunching noise on the tile, my first question is does the toliet rock at all? i would try and tighten the bolts on the base or the next step would be to pull the toliet and put a new wax ring then tighten it down. It makes a crunching sound because part of it is hitting the tile so makes sure it tight to the floor
