SOURCE: Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid. This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller. This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on. If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
SOURCE: melted carousel in microwave / bad smell
For the smell, do a Google search for "smell microwave" or "odor microwave" for many great tips.
If you need a new turntable support, you can order Sharp parts from Tritronics at http://www.wehaveparts.com
It's part # FROLPB017MRK0
SOURCE: Generic problem for all Kenmore Microwave
Loud hum is usually due to faulty hv diod, resonance capacitor, or the magnatrone feed thru capacitor , chk it with a ohm meter , one by one n replace it .. zaheer Islamabad
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
Make sure the !!!!capacitor is
discharged!!!!! before attempting any sort of repair.
Check
the door interlock switches first then the high voltage diode with
either an AVO model 8 on high resistance range for short circuit, the
capacitor can fail and go short circuit, the feed fuse on the primary
of the high voltage transformer and then finally, the magnetron is
best checked by substitution.
Hope that helps.
Check
feed fuse on the primary of the high voltage transformer and then
finally, the magnetron is best checked by substitution.
Hope that
helps.
