Umax AstraPix PC200 Webcam Logo
A
Anonymous Posted on Jan 01, 2011
From where we get software - Umax AstraPix PC200 Webcam
1helpful
3answers
Hello... nokia n73 my device software is V4.0726.2.04,can you help me to update it?tnx and more power
first of all you have to download the software updater from the nokia webite..and once your done,connect your cellphone to the computer with a USB cable..
update software:
With device software updates and application updates, you can get new features and enhanced functions for your device. Updating the software may also improve your device performance. You can update your device's software using the Software Updater in your device or using the Software Updater PC application. Learn how to update your device's software using both methods.
It is recommended that you back up your personal data before updating your device software.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting. installation of an update.
Downloading software updates may involve the transmission of large amounts of data (network service). Make sure that the device battery has enough power, or connect the charger before starting the update. After you update your device software or applications, the instructions in the user guide may no longer be up to date.
Update device software using your PC You can use the Nokia Software Updater PC application to update your device software. To update your device software, you need a compatible PC, a high-speed internet connection, and a compatible USB data cable to connect your device to the PC.
To get more information and to download the Nokia Software Updater application, go to www.nokia.com.ph/softwareupdate.
Update software over the air Your service provider may send device software updates over the air directly to your device (network service). This option may not be available, depending on your device.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting installation of an update.
Request a software update
  1. Select Menu > Ctrl. panel > SW update.
  2. The device scans for available updates.
  3. Select the desired update from the list, and follow the instructions on the screen.
  4. If the installation was cancelled after the download, to start the installation, select Install sw update.
The software update may take several minutes. If there are problems with the installation, contact your service provider.
3answers
Need free printer software
We need to know which printer you need software for !!!
If you are looking for printing software, simply do an internet search for "free printing software" or go to www.download.com and have a look under business software..
Top Umax Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Umax Computer and Internet Expert? Answer questions, earn points and help others
