Hi, unfortunately HP does not provide a driver for Windows Server 2003. Your only options for installing this printer is to try one of the other drivers (such as XP or Vista), or finding a similar printer that does support Server 2003 and using that driver instead. Since most drivers use the PCL language, you may be able to get away with using another printer's driver (though you may lose some functionality).
right click the driver setup file and click on properties. In the properties window go to compatibility tab and choose 'run this program on compatibility mode' and select windows xp. Now click and try running the setup again. Hopefully it might help you solve the problem.
BestRegards
NextDoorNerd
Here is the link from where you can download the drivers (Windows XP) that will work with Windows 2003 Server.
Click Here
Select Windows XP from the list, download and install that driver... It is compatible with Windows 2003 server edition...
Best of Luck, Please Do RATE the solution, if found helpful, Concerned.
