Sony KP-53V80 53" Rear Projection Television Logo
Posted on Jan 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red tube wont align,red ghost shadows on the picture
Electro Med Services
Level 3:
  • Sony Master 6,694 Answers
  • Posted on Jan 01, 2011
Sony Master
Level 3:
Answers
6694
Questions
Helped
1872104
Points
21433
check the red guns crt base socket . may be it have some problem. when u change the crt base try to change all the three guns base socket.
ok
Red is ghosting to the right. i replaced the convergence tubes about 6 months ago. went with the expensive ones "not the cheapy's" used heat sync putty stuff and everything. the problem is...
Yes,the tv problems it is the same,it is the tv convergence problems again,now it just color it is shaded in shadows pictures,instead of wavies mis colors R,G,B mis alignments.Yes.The tv convergence board it is the problems,must be repair again.
1helpful
Akai PT5598HDI Rear Screen Projection TV With Blue Shadowing
If the ghosting is like a 3D effect its your convergence ICs , but if its like a blue Halo around objects that usually means your CRT coolant has congealed and will need replacement. The blue is the first tube to congeal for some reason, followed by green. Red seems to be not quite as prone to this. It is a normal occurrence n sets about 4 years old to need the coolant changed.
My Hitachi 43fdx01B went from a perfectly clear picture to one with red "ghosts" and very blurry. I my TV toast?
No,ur tv have a problems,known as a convergence problems,it dead.Very common problems on the DLP tvs design flaw.Most commom problems are R,G,B mis alignment,will not align,Colors shadows pictures,3D pictured and blurry?The tv convergence board require changing the 2 STK convergence ICS and some or all it resistors are dead,must changes to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Ghosting comes and goes
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2helpful
Ghost shadows on the Sony KP-46WT500TV
you can get the KP46WT510 convergence repair kit at the following link under convergence repair kits category which will also work for your model.
http://servicemanuals.vstore.ca/
Color ghosting or shadows
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sony kp-48s75, shadow or ghosting picture
*Screen Looks 3-D
*Colors wont align
Problem #2
Ghosting - colored shadows - guns out of alignment?
*Screen Looks 3-D
*Colors wont align
Problem #2
Red and green shadows
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Tv has a ghost image in red
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
