Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television Logo
Posted on Jan 01, 2011
How do i connect compnents to get regular digital tv on my sylvania 6842pem tv
4 Related Answers
A
Anonymous
  • Posted on Jul 12, 2007
SOURCE: standby mode
It happened to me.. a FAx to Enrique. in California.
Anonymous
  • 6 Answers
  • Posted on Nov 28, 2008
SOURCE: Sylvania Power Board
I had the same issue. Turned out to be a blown capacitor on the power board.
<a href="http://s133.photobucket.com/albums/q68/rwlib3/?action=view&current=DSC_0426.jpg" target="_blank">
Anonymous
  • 5 Answers
  • Posted on Feb 21, 2009
SOURCE: my new sylvania dvd/tv wont get digital
Is that over the air or on cable?
dholaday
  • 226 Answers
  • Posted on Jul 20, 2009
SOURCE: tv turns on and then right back off
it sounds like one of the boards are going out I would call sylvania and check with there service dept maybe they can send a tech and part out under warranty
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Is my ILO 42" "EDTV" plasma ready for just a regular antenna?
No, it doesn't have a digital tuner. If you want to watch digital channels you will have to acquire a digital set-top box and connect it to the tv thru the av inputs.
3helpful
Tv turns on and then right back off
No TV
Do you have the remote? Try changing the INPUT to AVI, AV2, Compnent, etc.
1helpful
Hi I have a sylvania 6842pem 42 inch plasma. when turning the television on it makes a weird screeching noise then goes to stand by. what can the problem be thanks for the help
your transformer on your power supply is bad, i would recomend replacing the power supply, usually when the transformer goes bad , it damages other things on the board, should be around a 200$ part
I have a 42 in Sylvania 6842PEM. When it warms up, it will shut itself off. I power it back on, it may stay on for seconds or 30 minutes. Any ideas?
If the set appears to operate normally other than the shutdown, it may be a case of either a thermal problem in some component or bad solder connections. I'd suspect solder connections first since they are a major source of trouble in today's TV's. Unfortunately, these problems can be hard to track down. Spray cans of cooler (similar to spray duster for computers) can be used to try locating a thermal problem. Gentle tapping on the circuit board with an insulated tool and close inspection can help find bad connections. Working on an operating TV exposes dangerous voltages and fragile components, so care must be used. If you are not experienced working around electronic circuits, you might consider getting a professional to give an estimate for the repair.
1helpful
Need transistor
Finally I have managed to fix my plasma 6842PEM. My problem was the SS (Sustain) Board and not the Power supply. This board is the vertical one to the right connecting to the Screen/Panel. I tested every component on the board and found one of the Transistors on the heat sink was bad, part # 2PG001. This board is made by Panasonic which can be replaced. I got the Transistor which only cost $20.00 including shipping.
To identify wether this is your problem, disconnect the cable comming from the power board and put on the TV, If the green light stays on then this is your problem.
Thanks all for your help.
Laz
Power Supply
No. They are entirely different. Panasonic was the supplier of the 6842PE and Funai was the supplier of the 6842PEM.
1helpful
2answers
1helpful
4answers
Standby mode
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
