Step 1. Go to your local pool supply store or go online to any of several pool supply companies
Step 2. Buy a Winterization Kit. Usually the smallest size kit is for up to 5000 gallons, which would be the right size for your 15' pool. The kit will be a little less expensive than buying each of the chemicals separately and will include instructions.
Step 3. Follow instructions on the Winterization Kit package (which will tell you what order to use the chemicals in the kit and how to do it).
Step 4. Be sure to drain your filter completely. Even after the filter has been drained, if possible move the filter inside where it won't freeze.
Your convegence may have gone out. You can get complete kits with instructions from sites such as www.TvRepairKits.com or just the parts from www.ConvergenceChips.com . If you have never done this before i would suggest going the kit route since it includes step by step photo instructions and support.
Your convegence has gone out. You can get complete kits with instructions from sites such as www.TvRepairKits.com or just the parts from www.ConvergenceChips.com . If you have never done this before i would suggest going the kit route since it includes step by step photo instructions and support.
you will need to replace both of the STK392-560 convergence ICs then the six pico fuses on the D board will need to be checked and possibly replaced, the G board also has two pico fuses that may need replacement. The SONY Type 1 convergence repair kit is available from www.tvrepairworld.com which fits your model the kit contains the two ICs, with heat sink pastre, the D board picos and the G board picos plus the CD that has step by step instructions for the repair
That sounds like a Convergence IC issue. Have you tried the auto focus? If so does that stop short? If so its most likely the convergence. Your model uses the Sony Type 1 convergence repair kit available from www.tvrepairworld.com the kit also contains the step by step instructions on cd along wth the ICs and pico fuses.
The bit set you're is for the purpose of making cabinet doors, cabinet pulls and door pulls. It's a great little system from a good company. Unfortunately, it's intended to be used by people who have routed before. I don't know what your experience level is this stuff but you have several different types of bits there. You're not going to find step by step instruction on this kit, but what you can find is instructions for the different "type" of bits. For example, the kit includes a 99-510, which is a raided panel bit. Do a search for that. Freud won't give a step by step on that kit, but the styles (not stiles) they offer are universal. Also, here's 2 good resources. A picture's worth a thousand words and I think some of the illustrations will help. Remember, test your cuts on scrap stock, don't waste the good material.
Happy routing
http://www.newwoodworker.com/bldraspnldors.html
http://www.binkyswoodworking.com/RaisedPanelDoor.html
You need two STK392-110 ICs and the six feed resistors. You can get the complete kit at the following link which includes both Ics and the resistors along with step by step instructions on how to do the repair. The Kit you need is the Panasonic convergence repair kit type1. Heres the link. http://servicemanuals.vstore.ca/
You need the DM repair kit called the V21 / v19 DM repair kit which contains the parts and step by stepp instructions with pictures to repair the most likely cuase for that symptom, and its less than a service manual cost and they include the service manual for free as a bonus on the instructional CD. Heres the link its under their repair kit section
