Uniden BC248CLT Base Scanner Logo
Posted on Jan 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to clear old codes of a scanner - Uniden BC248CLT Base Scanner
Anonymous
Level 3:
President:
  • Master 2,761 Answers
  • Posted on Jan 01, 2011
Anonymous
Master
Level 3:
President:
Answers
2761
Questions
Helped
933298
Points
7369
I don't know of any global RESET function for your model scanner, but you can clear/delete the frequency (they're not codes) in any channel by programming 0 (zero) into the channel. Also, programming any new frequency into a channel automatically deletes/overwrites the previously programmed frequency.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC248CLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
2answers
I have a 04 pontiac montana.I want 2 clear codes(auto zone said they couldn't) so I can find out what's wrong with my van.It keeps throwing old codes so we don't know which are current. How would I?
Buy a scanner at autozone about $50 and clear them. That way you will be able to scan your self and know what is wrong with van. I have my own scanners
I HAVE CODE ERREUR WITH CANON ADV IRC2020L; the machine display code erreur E248.001
Have you downloaded latest update prog.
Remove the old programme then reinstall latest update.
CLEAR TROUBLECODES 1995 AEROSTAR
The codes should be cleared with a scanner. However, on a 1995 Aerostar, we are talking about an old EEC-IV system. You cannot clear codes on that vehicle with a generic OBD code reader because it is not OBD compatible. You need to get access to a Ford "Star Tester" or an aftermarket scanner that can emulate a star tester.
Codes can also be cleared on that system by disconnecting the negative battery cable, but this is NOT the recommended procedure because disconnecting and reconnecting the battery cable can cause voltage spikes that can damage sensitive computer equipment in your vehicle. If you decide to do it this way, make sure that you leave the battery disconnected for a minimum of 15 minutes before reconnecting the cable.
1helpful
I want to clear all frequencys out of scanner
Turn off the scanner.
While holding down 2, 9, and Hold, turn on the
scanner. It takes about 3 seconds to initialize
and "CLEAr" appears.
The above is from the "Resetting the Scanner" section on page 53 of the manual.
Lost owners manuel. need code install instructions. and also how to clear off all old codes
There is no general reset function that will clear all of the frequencies (they're not codes) from your scanner, but there are two ways to clear individual frequencies:
1. Programming "0.0" (zero point zero) into a channel will remove the programmed frequency.
2. Programming a new frequency into any channel will remove/override the previously programmed frequency.
You can download and print the manual for your scanner, at no cost, here:
Bill B.
KEEPS CODING 5 cylinder misfire. Replaced plug,plug wire,coil pack. Still coding. Any suggestions?
Clear the computer. Either use a scanner or disconnect the NEG battery cable for 10 minutes. The old defect takes 25 to 35 startups to clear itself. Then there is the possibility that #5 is a different cylinder on that motor. The engine may be misfiring because of a bad injector on #5.
My engine management light is on the whole time and i only bought the car. does that sound bad
It depends on Why it's on. It could be an old code indicating a fault that has been corrected, but the code was not cleared, or it could be an existing issue. You have to have the code(s) read by a scanner and see what is indicated. Note the code, have it cleared, and see if it comes back. If ^^^so, it'll have to be dealt with. If not, it was a random event that has cleaned itself up or it's an old code that indicates a problem that no longer exists.
5helpful
2answers
Clearing out old channels on a radio shack pro 95 scanner
Turn it on, and when "Welcome" appears, press zero, then press one. It will display a message indicating it is initializing to the factory state.
1helpful
I have a 02 TB and throws a code of P1271 I changed the apps and it still is giving the code I checked chevy forums last night and some said check the fan cluch I cleared the codes unpluged the fan and no...
you have to clear code with a scanner sorry hope this helps i to have had better days if you cleared codes with scanner then try unhooking batterie for 2 minutes negative side then clear with scanner again and recheack scanner for code you must clear with a scanner there is no other way
How do you clear all channels so i can put the channels that i want in it
There is no need to clear the scanner before reprogramming. When you enter a new frequency it will automatically overwrite the old frequency. To clear unwanted frequencies you can program "0.0" into any channel to clear it, or simply use the LOCKOUT feature to prevent the scanner from stopping on a channel.
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
