Belkin Surf N300 Wireless N Router Logo
A
Anonymous Posted on Nov 04, 2017
I have hooked up mthe belkin surf N300 wireless N router neither my laptop or ipad have internet access. The symbo;l says "connected to the belkin router via Ethernet cable. When I ckick on the Bekin user log icon ther is a line that says E: tz setting errorand on the line under that wnR2E2. I would appreciate any help. thank you
netrider
Level 1:
Habit-Forming:
New Friend:
  • Contributor 6 Answers
  • Posted on Nov 04, 2017
netrider
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
6
Questions
0
Helped
638
Points
17
Is the router showing you the correct network when you view the available wireless networks?
2 Related Answers
Falling star
  • 236 Answers
  • Posted on Apr 30, 2011
SOURCE: i have successfully installed a
here is the manual http://cache-www.belkin.com/support/dl/8820ed00372_f7d2301_v1_uk.pdf
look up under your wireless security as it isnt set up right either in the router or on your computer.
look at page 8 to 13 of the PDF and follow the set up again. you will need the wire plugged in while doing this process but afterwords you can go wireless after a reboot.
Anonymous
  • 84 Answers
  • Posted on Jul 04, 2011
SOURCE: Newly purchased Belkin Surf N300
There will be a lot of possible reasons on that, might be the wireless settings of your computer , you may try to remove all the old networks saved in your laptop and try connecting to it again,heres how 1. locate the wireless icon at the lower right hand corner of your laptop 2. Click on View available wireless settings 3. Click on Change advance Settings on the left side 4. You will have a small window with 3 tabs, one is general but just look for wireless tab 5. Box below you will see the list of the wireless name that was saved . 6. Delete everything, then make sure you apply it if there is or clicking on OK will do 7.Then try connecting again and make sure your password is correct.
or it might be your security application, try checking it and see if there's need to change especially if you got norton installed in your computer, try uninstalling and reinstalling it.
N300 router will not allow my apple hardware to print to my air printer
Hi, yes it could be a problem with bonjour support in router, maybe you need to update firmware, the steps to do it are in the following link: Updating your Belkin routers firmware
Cd wont work in my computer
You can setup your Belkin without an installation CD.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
1helpful
My mac laptop can't connect to belkin n300 router wirelessly
There is a small piece of paper underneath the router with original passwords, and the default was WPA security.
Hold the reset in the back till it cycles to remove any custom settings.
How do i connect ipad to belkin wireless router
..just look for your network name or ssid .. on the ipad.. if it will ask you for a password just type in your network key..
Trying to connect my ipad 2 to wi fi via belkin surf n 300 wireless router put password in and message camesup "unable to join the network "Belkin.361B"
Before you start :
Make Sure the Wireless Switch on your Computer is turned Off (If you are using a laptop to connect to the router )
Make sure that the Light on the Router is Solid Green
Step 1 : connect a computer to the router (Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
I have successfully installed a belkin surf n300 wireless router to my laptop, i can connect to the internet via ethernet cabler but when i disconnect the cable i lose the internet connection. how do i...
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
