Vacuums Logo
Posted on Jan 07, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Riccar 8750, when I plug it in any outlet and turn on the headlight does not come on and the vacuum does not turn on. The reset button does not seem to help. It worked fine when I shut it off last use. I changed the bag and all the filters, hit reset, and nothing? Any help would be appreciated
Thatvacguy.com
Level 3:
  • Riccar Master 1,619 Answers
  • Posted on Apr 28, 2018
Thatvacguy.com
Riccar Master
Level 3:
Answers
1619
Questions
0
Helped
605009
Points
3345
An 8750 is likely at least 20 years old but still may have lots of life left. I still have 8600 series Riccar vacuums brought in to my vacuum shop for service. You may have a loose wire, bad switch or power cord. I would take it to my local Riccar dealer to diagnose and repair.
4 Related Answers
A
Anonymous
  • Posted on Nov 04, 2007
SOURCE: riccar 8750
There's a small red button about one inch to the right of the left wheel.
Anonymous
  • Posted on Apr 19, 2008
SOURCE: riccar 8750
I have an 8625 and the button is now white not red. Probably fadded. Thanks that was the reset button and it solved my problem.
Anonymous
  • 231 Answers
  • Posted on Jan 03, 2010
SOURCE: vacuum bag was full and my wife did not clean it
there should be a reset button somewhere on the unit. press it in and then try it.
Anonymous
  • 30 Answers
  • Posted on Jul 13, 2011
SOURCE: riccar 1700 won't power on, outlet is working, no
If this problem happened after you replaced the filters, check that the filters have been installed correctly because some filters have sensor magnets installed on them and unless they are in their correct position, the machine wont power on.
I hope this helps you
MobileJB
Riccar 8850 Upright Vacuum Cleaner. I need a wiring diagram for it please?
Question edited for clarity and typo.
There is no wiring diagram available
https://www.google.com/search?q=riccar+8850+wiring+diagram
There is a video though
Or you could ask the maker?
Vacuum Cleaner Operating Instructions
Riccar http://media.riccar.com > 8000_Owners_Manual
How to Replace the Agitator Belt. (Models 8750 8850 & 8800 only). Unplug the units power cord. Turn the unit over and remove the bottom plate as described in ...
13 pages
Riccar r30d I have checked the hose and tried the reset. The bag was just put on and I took it off and put on again. When I plug it in now the lights turn on but nothing at all happens.
When you press the reset button you must make sure to push it in far enough. You may need to use a small tool to make sure you are getting it reset. Your Riccar vacuum is still under warranty. If it is not the reset button I suggest you take it back to your dealer for repair.
Contempo. Where is reset button on rear?
Reset button is at bottom on the rear of vacuum.
Why wont the reset button depress on riccar 8955 or turn on after trying
The reset button does not have a significant amount of movement in response to pressing to with a paper clip or ball point pen. If the vacuum does not start upon pressing the button, then either the thermal protection circuit is not why the vacuum stopped in the first place or the reason the thermal protection circuit tripped has not been cleared. Quoting from the manual
"Your Riccar vacuum cleaner comes equipped with a Manual Reset Thermal Fuse Protector. This thermal protector is designed to protect your vacuum cleaner from overheating due to a restriction in airflow (i.e. clogged hose, operating the vacuum without a bag). Should this situation occur, the thermal fuse protector will safely shut off the vacuum cleaner to avoid any potential damage. NOTE: To determine it was the thermal fuse protector that turned off your vacuum
cleaner, please refer to the vacuum cleaner's headlight. If the headlight is on while the motor is off, then the thermal fuse protector did safely shut down the motor. If both the headlight and motor are off, then there is some reason other than the thermal protector (i.e. pulled plug) your vacuum is off.
To reset the thermal fuse:
. Unplug the vacuum cleaner
  1. Check for problem - over-filled bag, clog in hose, clogged filters, etc.
  2. Correct problem
  3. Locate "tripped" fuse - the small white button located on the bottom of the back side of the main body (roughly one inch to the right of the left wheel)
  4. Using a pencil, paper clip or other pointed object, push the reset button in
  5. Plug vacuum cleaner in and resume use"
How to install belt on Riccar 8750 commerical vacume cleaner?
No. There is only one belt. Remove the bottom plate to gain access to the belt.
Dont owners manual
Get a new belt. If that doesn't take care of it, replace the rubber motor mount and metal pivot. Your vacuum is probably close to 20 years old and has some worn parts.
2helpful
Reset button power
Reset switch is located on the back of the vacuum and close to the back wheels.Press a reset switch a few times and vacuum should start. Check also cord plug . Many times metal prongs are broken at the end of the cord (usually one of them)
How do I replace the belt on my ricaar model 8750 vacuum?
Remove the bottom plate to access the brush roll. Remove the brush roll to install a new belt. Your
model is over 20 years old. If it has never been Professionally serviced it may be wise to take it to a Riccar dealer for service. It could add many more years of life to your vacuum.
1helpful
My Riccar 8850 stopped running. Changed the bag and cleared all hoses. Light comes on but the motor doesn't operate. I can turn the brush freely by hand.
Greetings from GoVacuum,
If the light on your Riccar 8850 is coming on, but the motor is not coming on, this indicates that your motor has gone bad. There is a reset switch on the back of the vacuum cleaner that sometimes trips if the bag is too full, or the filters are not maintained, but when this happens nothing on the vacuum comes on including the headlight. If the headlight is coming on, this indicates that electricity is making it down to the headlight, and the current is going through, but just not activating the motor. This is a tell tale sign of your motor being bad, and needing replacement. You can purchase the motor for the Riccar 8850 (12 AMP, 2 stage motor, Riccar part D113-1700 $122.44) from GoVacuum by giving us a call, as we don't yet have this part on our website.
I hope this helped you. We have been fixing Riccar's for over 30 years, and they are great vacuum cleaners, and the age of the model 8850 is probably the life expectancy of this vacuum cleaner.
Chris Jones
GoVacuum.com
3helpful
3answers
Riccar 8750
Top Riccar Vacuums Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
