This can be frustrated the first few times. Here's the likely issue: the wii version will not activate the keyboard (or drums) if multiple wii remotes are active and all-instruments mode is not enabled.
The multiple wii remote thing: one remote is considered the microphone, and the rest guitar controllers (you can use the wii-remote based wingman and guitar hero guitars with this title). Once you get to two plus wii remotes on, you can't add more.
So, assuming one of your guitar controllers is active, use it to go into the menu system and turn all instruments mode on. Once done, a wii remote is no longer needed to be used for singing, and now singing will be turned on by default (but you can ignore it). Now, your drums and keyboard should work fine.
Eventually, the game smartens up and turns on this mode automatically for you, but the first few times it does not. I nearly threw the game out the window the first day or so.
HI there! i have the same issue, and i follow your solution, but still the same, my drums works fine, it's only the kayboard which no't.
Ok , i won't lie . My wii is hacked, so i don't know if that may is the issue, and if it is, can be solved just with buying the original game?.
Hi there. If you are using a hacked Wii, and can change the IOS that the game uses, use IOS223. I have WiiFlow and I had the same problem, but looking on the internet, keyboards for this game use IOS223. Hope this helps.
