I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dear Mike, faulty RTC prevents from accessing the BIOS. i suggest that you may check the RTC is fine. Thats what happened to me and the second RTC worked just fine.
Good Luck!
The above suggestion made by CreativeTECH is justified. Rest assure that the RTC CMOS is the only issue. Check if the voltage of battery is ok. Takecare
Guys...
voltage 2.9 volts - near enough to 3 volts ??
just replace the CMOS battery with another new on @ 3 volts.
Same problem.
Any ideas ???
Hi Mike,
As we are here to help and assist each other, I assure you my best cooperation/efforts to the best of my knowledge and experience. I have spent hours digging out the issue. Checked the troubleshooting guide, Repair manual etc. (available at Official IBM Support) and Im still suspecting CMOS failure in some way as the behavior of the system is just the same as if without a CMOS (that can be verified by booting the system without COMS and without pressing any key from the keyboard, Im sure you would get the exactly the same message).
All I can think of now is that CMOS may not be having proper connection with the motherboard. Checkout the minute solders below the CMOS plastic housing (these may require re-soldering). Also, make sure that the keyboard is properly fixed. Its ribbon cable etc. and the system should respond to the keyboard. I wish for luck.
Watch for the status message "To interrupt normal startup, press the blue ThinkVantage button" to appear on the screen. The only time you have the ability to access your BIOS is while this message is on your monitor. If this message disappears, you will have to restart your T60 and try again.
Press the "ThinkVantage" button on your T60. From the list of options that appears, select "Start setup utility." You will be prompted to enter your BIOS password. Type "merlin" and hit "Enter" to bypass the password prompt using your backdoor password and enter your main BIOS utility.
Select "Security." In this window, select "Set Password." Type the new password you want to use for your BIOS. Press "Enter" to finish resetting your T60 BIOS password.
Dear Creative Tech
Reading my problem above you should see that I have just [ 2 hours ago ] replaced the CMOS battery with a new one. A simple job.
What other suggestions do you have please ???????
