SOURCE: internet connection of psp
To connect to the internet on your PSP, you need a Wireless Router or Wireless Access Point. Once you have a wireless one, you should know the name of your router. That's what an SSID (Service Set Identifier) is.
Once you know this information you should be able to find your router on your PSP. Once you do you should have a password on your router so no one you don't know can use your internet. When adding a connection on your PSP you will also need to enter the password for your router. You can use WEP, WPA-PSK (TKIP) or WPA-PSK (AES). WPA-PSK (TKIP) or WPA-PSK (AES) have very high security and WEP has a lower security.
Once you have added your connection, just type an address and surf! Not all websites will load because some require too much memory.
Assuming you have Official SONY PSP Firmware, Update to the latest version by going to Settings>Network Update. Locate your router and use it as the network connection.
Download the needed files and update by going to Game>Memory Stick>PSP Update.
Once you finish Update, go to Network>Internet Radio>About Internet radio. It will take you to a website to download the files needed and will install to your Memory Stick.
To put music on your Memory Stick, the Music must be MP3, AAC, M4A or WMA format.
Open your memory stick on your computer by pluggin in a USB cable to your PSP and going to Network>USB Connection or you can put the memory stick in a card reader.
Once in the root of your memory stick, there should be a folder called "Music". Put your music in there or in one more folder inside that. Two folders inside of each other will not be playable.
Place videos in the "Video" folder on the root of your memory stick.
Videos need to be MP4 format. 368X208 Highest MPEG4 Codec, or 480X272 x264 or AVC codec.
Need a converter?
http://www.formatoz.com/
Its a free and very good converter. Try it
Reply if you need anything else.
SOURCE: cannot connect ds to wireless router - Huawei Echolife 520s
Ensure that the B type is enabled in your router and that the security it set to WEP and that your passcode is correct.
HTH
SOURCE: PS3 can't detect access point
i have some solutions..
1. if there's lots of walls between the router and your ps3 it may not detect the signal. i had a very weak signal until i moved some stuff around.
2. you can manually type in your wireless name and i think it should at least reconize it, and maybe connect.
3. make sure theres no firewalls or anything to block other connections from entering your signal.
thats all i can say, sorry im not a tech guy-only 17!
SOURCE: Can't connect to the internet
you need to go into your routers settings and lower the security settings, with things like PSP's and DS's you need to have a lower access the wi-fi
