Televison & Video Logo
Posted on Jul 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
42 inch philips plasma HDTV vertical bar on screen
I have a 42 inch philips plasma HDTV. It's about 4 years old. After it's on for about an hour a vertical bar about 9 inches high and 1 inch wide appears in the upper right corner. What do I need to do to fix this problem? I've rebooted the TV and I've tried to move the picture frame right or left to see if it was off center. Neither has produced results.
  • jmansour216 Jul 08, 2008
    sometime it's a solid bar and sometime it's a bunch of vertical bars of different colors, but the overall size is the same.
  • Anonymous Mar 16, 2014
    cannot get teletext on bbc1 also picture is a bit hazy i have it running through a booster tryed retuning but still the same
Anonymous
Level 3:
Guru:
  • Master 1,894 Answers
  • Posted on Jul 08, 2008
Anonymous
Master
Level 3:
Guru:
Answers
1894
Questions
13
Helped
563444
Points
4850
Does the vertical lines appear like solid vertical bard infront of the pictire??
  • Anonymous Jul 08, 2008
    the lines are most likely the panel which isn't cheap..
    the lines are just a voltage adj. on the y sistain. if you feel confident enough you could try this yourself(though expensive equipment is usually required i do without). what you would have to do is take off the back panel if you have a stand put it back on that. easier to work on. then plug it. BE CAREFUL not to touch anything inside!!! from the back you will see a board on the left side on that board will be a small board attached vertically it will have a gray screw attached(very small). with the tv on you adj. the screw until the lines goes away(a little does alot).
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
42 inch LG plasma
Check the COF panels if there are SMD resistors on it,resoldering the resisters could fix the problem.
2answers
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
3helpful
3answers
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
2helpful
2answers
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Vertical bar on Daewoo Plasma screen
try this, can't hurt!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
st
10helpful
3answers
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me [email protected]
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
