Question about Garmin eTrex Vista GPS Receiver
Rubber band around case got loose, then broken
First: I am reasonably satisfied with my E-trex Vista, which I purchased in 2003 (it was a truly Expensive-First-Class-De-Luxe purchase then), and keeps soldiering on loyally over my auto dashboard after five years.
Yes, the screen tends to draw strange lines all of a sudden, image disappears or gets crazy, but that can be solved by removing batteries for a reset, or hitting it gently over the Earth-like logo with two fingers.
And yes, that joystick-like little thing tends not to react to movement when you most need to change a route or a waypoint; that usually gets fixed as soon as you turn on or off the screen light. I sincerely hope Garmin has corrected such flaws in later versions.
But REAL trouble is with that cute black rubber band... at first sight, it seems to be a good and simple idea: looks cool, gets a soft-handling feeling, makes the unit easy to operate, softens impacts, well, all fine. But that's just for a while (ok, that while amounts to a few thousand miles, but that's what an automobile GPS is supposed to resist, isn't it?).
I always remove the GPS from the sun when the car is parked for more than a few minutes, but anyway, on its second year of roaming, glue started to melt when exposed to heat and handling the GPS got kind of sticky and unconfortable.
The third year the rubber band got loose and started moving around, spreading glue everywhere; most remarkably, all over the fingers of the person operating the GPS. I tried to glue it back, but I just did'nt find the right kind of adhesive, for it never fixed and made things worse. I also tried to tie almost any conceivable kind of thread and/or wire around the GPS, to keep the rubber in place, but to no avail.
The fourth year the rubber finally broke; let's say it lost its "O" shape to become an open "U", so it got impossible to keep it in place. Since then, I have found nobody, from Garmin.com all the way down to grass-roots dealers, who can offer me a replacement rubber band.
I suppose the cost of such replacement part should be much less than replacing, let's say, the LCD display or the satellite decoding chip (I'm guessing). But nobody would put it for sale: it's just a rubber band! It probably seems nonsense to advertise it among all those trendy accesories.
Now I'm operating the GPS... yes, by pushing the buttons extra-firmly over the water protecting layer (now fortunately clean of glue), for there is no rubber band anymore.
So... my questions are:
1. I need to find somebody somewhere who can sell me a new rubber band for a Garmin E-trex Vista.
2. I would like somebody to suggest Garmin people, back there in Kansas, to chose a reasonably heat-resistant glue, so their units can be actualy used over auto dashboards for long travels without desintegrating.
3. And, were that possible, may the rubber band be made from some kind of rubber that does not expand or break after repeated exposition to sun.
Thanks. I hope you can help me find a solution; otherwise, I have discharged my feelings anyway, so thanks again.
G. F. Kloss
  • Anonymous Aug 04, 2008
    I too could use a replacement band, but for a Garmin etrex Legned HCx. Even though the unit is quite rugged, it didn't hold up well to being chewed-on by my golden retriever. Fortunately the unit appears to function correctly. Unfortunately the soft band suffered irreparable damage. Any help in locating a source for a replacement band would be greatly appreciated.
  • capt3581 Nov 30, 2008
    My band has come loose also from just sitting in my vehicle in the back seat. Can't find anyone or any replacement for that piece also. I'd hate to have to buy another entire unit just to have the band back to normal.
I had the same problem with my Vista 1 year ago. I tried the contact cement and worked fine for a couple of weeks. I tried another brand of contact cement and had the same problem (the adhesive unsticks from the rubber band). I finally solve the problem cleaning everything (be sure to remove ALL of the adhesive from both gps and rubber band to ensure a good contact between them) and putting some drops of Locktite instant glue on the water protective layer side, and then carefully place the rubber band on its place (don't forget that you have only a few seconds to work with instant glue) . Just be carefull and don't apply adhesive very close to the buttons. It worked for me for more than 11 months....and still working...
Posted on Aug 10, 2008
I really need a rubber for my venture cx. Isn´t there any place where we could buy it?
I shoul be greatfull for solutions
bignando@gmail.com
Posted on Sep 05, 2008
I have the same issue and am now e-mailing with Garmin about it. I love my eTrex Legend Cx but the loose band, and associated goo is not good. My thought now is to take the band off, clean off all of the goo (that used to be glue) and use contact cement to re-install it.
Posted on Jul 23, 2008
Hi, I have exactly same problem. As matter of fact, I don't use GPS on the dashboard and still having the same problem.
I asked Garmin dealer and they said they can fix it at minimum repair charge which is $200. I think the rubber band cost is only $2-5 per unit. I can not afford it. If I pay $250, I can buy entire brand new etrex vista.
Posted on Jul 22, 2008
SOURCE:
Suggest causes for the 4L80E transmission not to reverse
No Reverse
Checks
Cause
Case (7)
The rear band anchor pin is broken or the pin is not positioned.
Center Support (640)
Leaking at the case, or the support is broken.
Center Support Seal (639)
Leaking
Center Support Bolt (25)
The bolt is loose or broken.
The feed hole is blocked.
Rear Band (657)
Broken, worn, or not anchored
Rear Band Apply Pin (73)
The pin is too short or the pin is binding in the case.
Piston (65)
Binding in the case
Seal (66)
Leaking, damaged, or worn
Gasket (63)
Damaged or displaced
Cover (62)
Damaged
Bolts (61)
Broken, loose, or missing
Checkball
Missing
Fluid Pressure
Too low
Direct Clutch Components
Reaction Plates (618)
The splines are worn.
Friction Plates (611)
The splines or the friction are worn.
Spring Assembly (607)
Jammed
Housing (623)
Cracked
Piston (619)
Leaking
Seal (620, 621, 622)
Leaking
Ball Check
Leaking
Dec 18, 2015 | 2001 Chevrolet Silverado
I have a porter cable rn 175a, barely used, driver will push 1 nail, and then has to be manually reset, any suggestions or solutions please
Driver not retracting is caused by check band around cylinder is not in place or broken. Easy to check. Remove the head and pull out the cylinder. There should be a black rubber band around series of pin-holes in cylinder. If the band is broken use any rubber that fits snuggly around cylinder and covers holes. Good luck
Mar 21, 2014 | Air Tools & Compressors
Cd changer will not eject 1999 rl
The ejection action is done by a small rubber band and when this happens it is normally the band has broken. It will require the cd unit to be removed and the cover taken off to see if this is the case.
Sep 29, 2013 | 2003 Acura 3.2CL
FN250A finish nailer will only shoot one nail then has to be manually reset
Could be caused by bent driver, piston oring too tight or too loose cylinder split or check band broken or slipped out of place. Easy to check. Remove the head and pull out the cylinder. Check band fits around series of very small holes on mid-lower part if cylinder. Check band looks like rubber band, should fit snugly around cylinder and cover the small holes (any band will do if broken, even many orings side by side). Driver should not be bent, if bent, try of adjust but use caution because it could break easily. The driver should fit into cylinder so that it does not fall thru cylinder under it's own weight. The driver should stay in place and moved with little effort. Good luck
Feb 07, 2013 | Porter Cable Air Tools & Compressors
How can replace the speaker the bass sound is broken
Dear Rob,
Really Thankful for the detailed description for the Speaker Repair.
It really helped me a lot. I have a unusual situation here with me. I have dissected the whole console and found the outer band of the speaker has just come off....have attached photos to make it clear. does the outer speaker cone will make a difference or i will have to replace the speakers itself.....when i checked pressing the speaker down and played the distortion had gone....but while playing without holding the distortion would come back....Hope you can help me in this situation....Thanks in Advance..... 714812a0-935e-4f95-922e-50c6ba281b9c.jpg 36e62701-6370-491a-a317-a11c69cc9525.jpg
Jan 13, 2013 | Harman Kardon Go + Play Portable Speaker...
Sony icf sw100 broken battery case (the tooth on which the battery lid hinges)
Re Sony ICF-SW100 battery case lid.Ive had same problem with battery case lids on this these units, I used a strong rubber band around the length of the whole battery case to keep lid in place as no parts available in Australia. Love the radio, have had 4 over many years.
Nov 11, 2010 | Sony ICF-SW100S Radio
Insert Sim problem on Nokia 1650
hi, it means the sim is not properly placed in it possition..what you can do in the main time is to change the case of the phone, so that you won't need to be using rubber band to hold phones together.
Jul 09, 2010 | Nokia 1650 Cell Phone
CANT BE HEARD MICROPHONE DOES NOT WORK IF I SQUEEZE THE BOTTOM OF THE PHONE AT THE EDGE IT WORKS BUT LATELY NOTHING AND MY FINGER HURTS
Hi, i think the body of the phone might be broken and it's allowing the screw area to be loosed, that's why you need to press before someone can hear you.
In cases like this, you will have to check the screws first if they are firm enough holding the phone, and also if the body of the phone is not broken somewhere around that area.
If is the screw, check if it needs to be tighten or replaced.
For the body, if broken you will need to get a new body to replace the old one.
Or better steal, you can use a rubber band to hold it.
Take care.
May 20, 2010 | Sony Ericsson TM506 Cell Phone
Epson 1400 Printer Banding and color issues.
Try to print without high speed. If it's ok, you need to head alignment both black and colour.
May 26, 2009 | Epson Stylus Photo 1400 Printer
Samsung CLP300 cannot get the rubber pick up roller back in
The rubber band goes around the plastic roller and is loose about loose enough to get a finger between it and plastic however the thing then pushes back into the curved space at the back of the roller so it forms a kind of c shape around the roller. If that makes any sense!
Aug 16, 2008 | Samsung CLP 300 Laser Printer
Garmin eTrex Vista GPS Receiver Logo
1,640 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
