A Hard Reset might help. it will bring lost file/folders back.
Also to turn on phone in safe mode, but not if cannot get passed initial Android screen.
Pull Battery to power off phone.
Hold Up Volume button, and power on button simultaneously until green android guy and DOS window open.
If Home key is solid button, then also hold
up vollume button, home button, power button.
use volume up and down to scroll.
Scroll down to Reset Manufacure Settings.
Use power button to select OKay.
Then select reboot system.
SOURCE: w850i Application/Games not opening
Actually, just got my back today from repair. Called Sony ericsson about the problem and they told me to send it in for repair. 'Cause it's under warranty (Which I wasn't asked if it was) I also went ahead and asked about the broken keypad. it took less than two weeks. Had to use my old s710. So far I have not been able to find a solution. Maybe flashing the phone could help. I think that's what they did. Because it looks like it came from SE instead of Att.
SOURCE: Nokia 6500slide screen fades to black and white then offs
Its a Virus Problem CommWarrior.
Format Ur Mobile.
SOURCE: I keep getting an error
Try this.
settings>applications>Manage applications>(select the "ALL" tab)>select "Market"
then "Clear data"
Download the latest market .apk file from
thegadgets.net, make sure you keep it in the root directory of SD card.
Once downloaded, install the market app with the help of apkinstaller
If still the problem persist hard reset your phone.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: I have a HTC SMART
This phone is considered more of a feature phone than a smart phone. Android hasn't been ported over for this phone and wouldn't run on it due to the limited amount of ram and processor in the phone. So even if you have an unlocked HTC Smart there is no way to run or emulate any of the Android operating systems on it.
Also BREW (the operating system on the HTC Smart) is NOT compatible with any Android Applications out there so you will not be able to run any of them on your current phone.
Sorry about your luck mate.
Testimonial: "thanks a lot, i got answer to my question!! i think the reply was the good one"
