Arris SURFboard Gateway SBG6580 DOCSIS 3.0 Wireless Cable Modem Logo
Posted on Dec 31, 2010
My ipad and my iphone wont connect to the wireless,
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4422
Points
7
The password that my Iphone required was the 20 digit key located on the sticker as WPA-PSK. Hope this helps someone!
  • Submit Miscellanea
    Submit Miscellanea Sep 12, 2015
    Thanks that cleared it up for me. I kept trying to use the password for accessing the modem settings.
Submit Miscellanea
Level 1:
New Friend:
  • Posted on Sep 12, 2015
Submit Miscellanea
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4422
Points
Thanks, man! I kept using the password for accessing the modem's settings. The instructions aren't very clear about that.
1helpful
Are your hdmi wireless extenders apple compatible?
Consider the HRpart Wireless HDMI Display Adapter. Here are the key details:
4K Screen Mirroring: This adapter allows you to view audio, video, and office documents from a small device (like an iPhone, iPad, or MacBook) on a larger screen (TV, monitor, or projector) without messy cables. It's perfect for presentations, meetings, and exhibitions.
Wireless and Easy Connection: Setting up this wireless HDMI adapter is straightforward. You'll need a 5V/2A power source (which can often be provided by a USB port near the HDMI input on modern TVs and projectors). If the port is occupied, a battery pack can also work.
No Need for Wi-Fi: The adapter is self-contained and doesn't require an internet connection. Once connected to an HDMI input and powered, it displays a helpful screen for easy connection. You can stream movies, videos, games, and office files from your Apple device to a high-definition TV or projector.
Compatibility: This device is more suitable for Apple devices, including iPhone models (such as iPhone 7 Plus, iPhone 8, iPhone XS, etc.), MacBook Pro, MacBook Air, and various iPad models (iPad Pro, iPad Air, iPad mini). However, please note that it does not support HDCP-protected applications like Netflix, Amazon Prime Video, Hulu, and others.
You can find this HRpart Wireless HDMI Display Adapter on Amazon 1. Keep in mind that it's designed specifically for Apple devices and provides a convenient way to mirror or cast your screen wirelessly.
tip
EPrinter Not Detecting iPhone or iPad to "Airprint" or "Direct Print"
I run an ePrinter wirelessly (WiFi) off a ASUS EA-N66 wireless repeater. This tip pertains to a HP 6525 printer in case you find this attempting to correct the same problem.
When first connected everything connected except the "Airprint" features or 'Direct Print" off my iPhone and iPad. I found the default printer settings were set to "Simultaneous IPv4 & IPv6". The iPhone/iPads communicate at IPv4. Theoretically they should function in the "Simultaneous IPv4 & IPv6" setting but they did not. Changing to the "IPv4" only setting corrected the issue and the printer functions with everything I have including a WiFi PC laptop, a Wifi Mac, iPhone and iPad.
HOW do i use wps on my ipad with WNR2000
Depending on your browser, download or display the pdf of the WNR2000 manual ( http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf ). The manual might also be found on the CD that came with the router.Follow instructions Chapter 2 Page 7 to enable/setup WPA2-PSK (AES).Make sure you SAVE/APPLY the settings before proceeding. Follow instructions Chapter 2 Page 17 to Disable Router's PIN. When you do, make sure you leave the box checked to "Keep Existing Wireless Settings".Make sure you SAVE/APPLY the settings before proceeding.Here's a work-around ff the above doesn't fix the issue for you. Sorry I don't have iPad-specific instructions, but I don't have access to an iPad/iPhone at the moment. I've done the following on iPads, iPhones, Android phones and tablets, Windows phones and PC's - it works on virtually all Wi-Fi-capable devices..:
Instead of letting your iPad find the network and trying to connect with the password, try manually creating a new Wi-Fi network connection by typing in your Wi-Fi network name (SSID), selecting WPA2 (AES) encryption and entering the Wi-Fi password your configured in STEP 2 above.Please note: You'll have to forget the Wi-Fi network in your iPad's settings if you keep your Wi-Fi network name (SSID) the same as it is currently.
2answers
How do I print from my i-pad?
has the ipad got a driver for the printer
Why wont my ipad charge
To charge an iPad you have to connect the USB cable to iPad power adapter (12W in power and is bigger in size compared to iPhone's). If you connect it to iPhone power adapter you might see that the iPad is not charging, but will take a very long time to charge. The same goes with connecting directly to computer.
Also, there is always a chance that either your cable, or adapter or the iPad itself has gone bad.
2answers
Iphone wont turn on
Hold the power button and home button down together for 10 seconds, or until you see a white apple.
My router was working fine with my iphone and ipad , now it will not connect and i still have a connection with my ps3
If you reset the router and have not turned off and back on all your devices you probably have conflicting addresses. some versions of ps3 will not connect for some reason unless they have the first ip available on the router.
Turn off your wirelss on your iphone and ipad, turn off the ps3. Reboot the router when it comes back up turn on the ps3 and get a good connection, the enable wireless on your ipad or iphone and get a connection the doe the same with the other.
This will avoid conflicting addresses.
An IP address has a 24 hour lease if you reboot a router it forgets what device had whipch ip address. If you need to reboot your router you need to refresh the ip address of all your devices to avoid conflicting ip's.
In this case I suspect you ipad and iphone are attempting to use the same ip address.
2helpful
2answers
Random wi-fi dropping
Go to the linksys website, see if they have a firmware flash for the router, that may help in some connectivity issues. You may also find that the ipad/iphone may drop connections when battery levels are low
I can't connect my iPhone and iPad via blutooth
iPad and iPhone have some limitations regarding bluetooth connectivity. I believe you will need an external application depending what do you want to do.
Top Arris Computers & Internet Experts
Jesse Walters
Jesse Walters
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
