How do you change English to Spanish on a Windows 7 computer...welcome screen & everything in Spanish...is it possible?
It depends a bit on your installation but you should be able to do this. First install the language if you need to. (Win7 Ultimate and Enterprise allow for Multiuser User Interface Pack; All other versions use Language Interface Pack and you must install the Parent language. Microsoft.com and search for the appropriate pack.) The LIP doesn't translate everything. Then in the Control Panel, click Clock, Region and Language. Then click Region and Language, the Keyboard tab will let you change the keyboard language and the Administrative tab will let you change the System Locale. Once you install the additional language, you'll also see a tab for Display Language. Set this to Spanish.
Hot keys are also available for switching on the fly once the language is installed. The Welcome Screen will get a Keyboard Layout button when more than one language is installed to switch languages then. (This can be locked for some users so see the Windows Help to find more information. It's still in the Region and Language section.)
If you only want the Spanish, consider reinstalling the OS with an international (or whatever MS calls it) version of the OS.
I hope this helps.
