Question about SanDisk Sansa c240 MP3 Player
Sansa sandisk c240
Mp3 was submersed in water it was let to dry out and when pluged in computer to charge it looks like its charging but when not hooked up it goes out compleatly.
  • 981 Answers
Water brings minerals in with it, so you have some mineral short-circuiting going on; just take it apart and soak it again in DI water, perhaps scrubbing a bit with a toothbrush and working the switches, and seeing if you can't treat or replace the battery separately. Then you get to dry it thoroughly (e.g. under the sun and a layer of cotton) and see if things have improved, and reassemble if it has. Don't forget to remove any micro-SD flash media in disassembling, that interface can sap power too.
The works are all solid state and the display module sealed pretty well, so you should be fine. Not to say you shouldn't grab a Zune 2 as well...
Posted on Jun 15, 2013
  • 8,596 Answers
Yeah, water damage = irreversible; everyone on this forum who has ever dried out their mp3 player failed to get a player that worked 100% of the time - call the manufacturer, Sandisk, and see if you are eligible to get a replacement - don't mention the water damage
Posted on Jul 08, 2008
SOURCE:
Can I use my Sandisk Sansa C240 while it is charging?
This is normal when the Sansa is connected to a computer. You can use it while charging if you connect it to something else. For example, you might have a cell phone with a USB charger that plugs into a wall outlet. You could connect the Sansa to it, and it would let you listen while charging.
May 01, 2010 | SanDisk Sansa c240 MP3 Player
Not charging
Try connecting directly to USB port on your computer, NOT a hub. It needs power to charge.
Apr 29, 2009 | SanDisk Sansa c240 MP3 Player
How to I start the c240 up it My computer doesnt
On Windows XP, when you open My Computer, the Sansa C240 shows up at the bottom, under "Other". Because of DRM restrictions, you cannot copy media files to the C240 using Windows Explorer. You have to use Windows Media Player to sync playlists to the C240 (WinAmp can do it also).
I also suggest that you check out RockBox. It's an alternative operating system for portable media players and they have a version for the Sansa C240. It will give you some additional functionality.
As far as I can tell, to copy files to the microSD card (if you're using one) you have to use a media card reader, then insert the card into the C240.
Mar 17, 2009 | SanDisk Sansa c240 MP3 Player
SanDisk Sansa c240 1gb driver problem for vista
try using sansa media converter you need quicktime player for it to work
Jan 25, 2009 | SanDisk Sansa c240 MP3 Player
My mp3 player wont turn on or charge
Make sure you plugged into a usb port on the computer, NOT the hub. It needs the power.
Jul 15, 2008 | SanDisk Sansa c240 MP3 Player
Broken mp3 player
It sounds like your device is deffective..What I would recommend you to do is to give Sandisk a call to see if they are willing to set you up for an RMA...their number is
1-866-726-3475
7 days a week:
4:00 am. - 10:00 pm. (PST)
7:00 am - 1:00 am (EST)
Please rate accordingly
Thank you
Computerrep
Mar 25, 2008 | SanDisk Sansa c240 MP3 Player
Battery Charging
most sansa players will; not charge on a laptop. plug it into a desktop
Jan 06, 2008 | SanDisk Sansa c240 MP3 Player
How to charge battery
Connect it to your computer using the usb cable provided.
It should show that the battery is charging.
Dec 25, 2007 | SanDisk Sansa c240 MP3 Player
Battery trouble
Just stop charging it and unplug it, then check on the top right of the screen to seen if it is fully charged.
Nov 25, 2007 | SanDisk Sansa c200 MP3 Player
Sansa c240 battery issue
Does it indicate that it is fully charged? If it does, I would return it or have it replaced. You have a 1 year warranty from SanDisk. SanDisk Technical Support 1-866-726-3475 If not, try using a different USB port on the computer, preferably one in the back. Best of Luck.
Sep 14, 2007 | Audio Players & Recorders
SanDisk Sansa c240 MP3 Player Logo
122 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
